Other render slots cleared after each render #44310
Closed
opened 2015-04-08 14:27:46 +02:00 by Greg Zaal · 8 comments
Member
Windows 7 64 bit, gtx 570
Broken: d5f1b9c2 (multiview commit)
Worked: 74df307c (previous commit)
Render slots in the image editor are cleared on every render, making it impossible to compare with a previous render.
  • Blend file: slot_bug.blend
  • Render to slot 1
  • Change to slot 2
  • Render again
Look back at slot 1 and see the old render is now gone
Note: I can't reproduce this in the default scene, but it consistently doesn't work with the blend file above - can't figure out why :(
**System Information** Windows 7 64 bit, gtx 570 **Blender Version** Broken: d5f1b9c2 (multiview commit) Worked: 74df307c (previous commit) **Short description of error** Render slots in the image editor are cleared on every render, making it impossible to compare with a previous render. **Exact steps for others to reproduce the error** - Blend file: [slot_bug.blend](https://archive.blender.org/developer/F159804/slot_bug.blend) - Render to slot 1 - Change to slot 2 - Render again # Look back at slot 1 and see the old render is now gone Note: I can't reproduce this in the default scene, but it consistently doesn't work with the blend file above - can't figure out why :(
Author
Member
Author
Member
Added subscriber: @GregZaal
Added subscriber: @Sergey
Dalai Felinto was assigned by Sergey Sharybin 2015-04-08 15:43:11 +02:00
Added subscriber: @pablovazquez
@venomgfx just reported that. The workaround is to manually click on pass COMBINED. Once you do that (after the first render, J, render) things work. I'm looking at the actual fix in the meantime
This issue was referenced by 5d212fb812
This issue was referenced by 5d212fb8121912cd583eadb55ea19c9bbab7b5e9
Closed by commit 5d212fb812.
Reference: blender/blender#44310
