Character motion actuator additive motion not working correct #44328
Closed
opened 2015-04-09 21:37:58 +02:00 by Thomas Szepe · 9 comments
Member
If there are two character motion actuators are used to get a waking and running speed the two values of the actuators are not added together if are both active.
The test characterBug2.blend file can be found in #36703
To reproduce the fault. Open the .blend file start the engine and press the up and then the shift key.
Actually we only can workaround this bug, if we disable the add on the second actuator and change the speed to the running speed.
A possible way to fix this bug would be to set the motion speed every frame for every character motion object to zero, then the character motion actuators can add the motion speed to the the actual one.
If there are two character motion actuators are used to get a waking and running speed the two values of the actuators are not added together if are both active. The test characterBug2.blend file can be found in #36703 To reproduce the fault. Open the .blend file start the engine and press the up and then the shift key. Actually we only can workaround this bug, if we disable the add on the second actuator and change the speed to the running speed. A possible way to fix this bug would be to set the motion speed every frame for every character motion object to zero, then the character motion actuators can add the motion speed to the the actual one.
Author
Member
Mitchell Stokes was assigned by Thomas Szepe 2015-04-09 21:37:58 +02:00
Author
Member
Added subscriber: @hg1
#34349 was marked as duplicate of this issue
I haven't looked at your blend file yet, but are you trying to add two vectors with the same direction? If so, the motion actuator normalizes the vector, so two vectors in the same direction will have no (extra) affect. Also, we now have three reports on the character motion actuator (this one, #34349, and #40682); could some of them be combined?
Author
Member
Added subscribers: @AngusHollands-4, @Moguri
Member
Added subscriber: @JorgeBernalMartinez
Member
Added subscriber: @Blendify
Member
Member
This task is being closed because the BGE has been removed in Blender 2.8.
5 Participants
Reference: blender/blender#44328
