Freestyle SVG exporter #44392
Blender Cloud
Documentation
Eevee & Viewport
Import and Export
Rendering & Cycles
Add-ons (BF-Blender)
Add-ons (Community)
Reference: blender/blender-addons#44392
OS: windows 8 64bit
GPU: NVIDIA 860M
Broken: (example: 2.69.7 4b206af, see splash screen)
Broken 2.74.4 (465a5d2)
when viewport rendering is enabled (internal renderer) and the addon activated in the render tab then there are errors.
this happens when the image is not first rendered with f12 and i think there should be a warning in this scenario that the image is missing instead of throwing errors in the system console which the normal user has not opened and wonders why nothing is rendered any more.
also when rendering blender crashes, heres a crashlog (this only seems to happen if frame step is set to 1, it runs through with 2 or 10 or whatever else i use)
Added subscriber: @DanielGrauer
Added subscribers: @kjym3, @JulianEisel
So it only prints the error and nothing else, right? @kjym3, think a warning should be fine here.
yes it only prints the error. i added a crash when rendering a animation which only seems to happen if the frame step is set to 1. but not sure its related to the addon or if its caused by something else.
Closed as duplicate of #43300
Thank you for the detailed problem report. The SVG exporter needs to be disabled temporarily when the view port rendering is ongoing. A technical issue here is that there is no established way to detect if the view port rendering is taking place as described in a comment for #43300. I have proposed a solution and been waiting for feedback from core developers.
i added an other bug report because of thee crash blender/blender#44404 it seems this is caused by the freestyle addon.
