python import crashes Blender #44466
Reference: blender/blender#44466
Windows 8.1 64 bit
EVGA 970 and EVGA 560Ti
Broken: 2.74 and 2.73
Worked: 2.72 and earlier
I create an import.txt file, which is a Blender python script that creates a bunch of materials (usually 3 or 4) including node layouts, and then imports a bunch of .obj files, performs some operations on them (translations, remove doubles, assign vertex group names, etc.
import.txt - import.txt
https://dl.dropboxusercontent.com/u/81602544/Urbanmech.zip - .obj and other needed files to do the import.
import.txt will need to be modified so that the paths match where you unzip the urbanmech.zip files. To modify, just do a find and replace for something like this:
filepath="e:\blender projects\mechs\objects\mechs\urbanmech\body\urbanmech_body_dif.dds"
The "e:\blender projects\mechs\objects\mechs will have to be replaced with the absolute path of where you extracted the zip file.
Bonus bug for 2.72 (working version, although present in all versions I've used): The display shows some objects as completely black, although a material is assigned. To fix this, you select one of the black objects, remove the material, and reassign it.
Added subscriber: @Geoffrey-Gerber
Thanks for the report, but crashing Blender from python can be dead easy if you do the wrong thing. You can’t expect us to debug your own code. So if you are able to reproduce the crash with only a few lines of code (and no need of a ton of additional files either), we can check whether this is an actual bug in Blender or an error in py code. Otherwise, we cannot do much with given data so far. Remember user has to do half of the work in a bug report - namely provide a simple, easy to reproduce example of the issue.
Should I open a new task, or can this one be opened? I can get the crash to work fairly consistently by just importing one object. Sometimes it works, sometimes it crashes. The more objects I import using code just like below, the more likely it will crash. Just cut and paste this code into Blender. Having the Obj file is probably needed (dropbox link provided). Having the material loaded up isn't necessary.
https://dl.dropboxusercontent.com/u/81602544/um_centre_torso.obj
This works just fine in 2.72. 2.73 and 2.74 will crash fairly consistently (but not every time).
bpy.ops.import_scene.obj(filepath="e:\blender projects\mechs\objects\mechs\urbanmech\body\um_centre_torso.obj",use_groups_as_vgroups=True,split_mode='OFF')
bpy.context.scene.objects.active=bpy.data.objects["um_centre_torso"]
bpy.context.active_object.rotation_mode="QUATERNION"
bpy.context.active_object.rotation_quaternion=[1.0,0.0,0.0,0.0]
bpy.ops.transform.translate(value=(0,0.63643,8.99755))
bpy.context.object.data.materials.clear()
bpy.ops.object.mode_set(mode = "EDIT")
bpy.ops.mesh.remove_doubles()
bpy.ops.mesh.tris_convert_to_quads()
bpy.ops.object.vertex_group_add()
bpy.context.object.vertex_groups.active.name = "COCKPIT"
bpy.ops.mesh.select_all(action='SELECT')
bpy.ops.object.vertex_group_assign()
bpy.ops.mesh.select_all(action='TOGGLE')
bpy.ops.object.mode_set(mode = "OBJECT")
bpy.context.object.data.materials.append(urbanmech_body)
Added subscriber: @sindra1961
Probably I think that it works if you add a script in this way.
When you allocate material without choosing vertex, it is not reflected.
It may be a cause that a script is wrong, but it is a fact that blender crashes.
blender catches an error, but crashes.
I think that this should revise it.
