Crash on deleting curve handle with hook modifier #44497
5 Participants
Reference: blender/blender#44497
Windows 8 64 bit
8 core CPU
GTX 660ti
24Gb DDR3 RAM
Broken: Windows 2.74 official 64bit and newest development build from builder.blender.org
Worked: Worked somewhat on Linux, though still unstable (thanks to Stan_Pancakes for testing)
In the .blend file I made a curve with one handle (the middle one) hooked (ctrl+h) onto an empty.
Entering Edit mode, deleting the outer curve handle with no hook and then the hooked handle and leaving the handle in the origin point will make it crash either when:
Sometimes it also crashes when deleting the hooked handle and leaving the other two handles connected, returning to Object Mode, reentering Edit Mode, undoing action and then returning to Object Mode
Clearer explanation below :)
Crash case 1:
1: On curve object, enter Edit Mode
2: Delete outer curve handle that is not in the origin point
3: Delete middle curve handle which is hooked onto the circle empty (crash?)
4: Return to Object Mode (crash?)
5: Re-enter Edit Mode (crash)
Crash case 2:
2: Delete middle curve handle which is hooked onto the circle empty
3: Return to Object Mode
4: Re-enter Edit Mode
5: Ctrl+Z undo the deletion of the middle curve handle
6: Return to Object Mode (crash)
I can replicate this problem completely on a new .blend with only the curve object and empty in it
Added subscriber: @mstuff
I forgot to add the .blend file :)10840.blend
A bit silly that I can't edit the report
Also, Stan_Pancakes tested all the steps above and found that his system crashes just like mine - No difference in Windows or Linux
Added subscriber: @Stan_Pancakes
Indeed (Stan_Pancakes being me), tested on 64-bit Linux with both 2.74 and 2.74-ecb3362, crashes as described.
Added subscriber: @Psy-Fi
Confirmed, I'm checking it out
Nice catch, too separate issues too.
Added subscriber: @Sergey
Second issue is out of bounds issue, it's easy to make it not crash but fixing it loses the indices to the hook - hook won't work anymore.
First issue is a race condition from depsgraph, @Sergey may want to take a look.
This issue was referenced by
4ffcc6ff56
