PNG format file sequence render corrupt randomly #44521
Reference: blender/blender#44521
Ubuntu 14.04 64bit, GTX 570
Broken: 2.74
Worked: -
I render the image sequence in .png format using terminal command "./blender -b {scene file} -a" and use multiple terminals and multiple computers to speed up the render time. The folder is on another harddrive which is WD My Book Live 2TB. All computer were connected via NAS. The result is some of the .png files randomly couldn't recognized by nautilus thumbnail and resulting in black preview on Blender VSE after editing. I'm using Blender Render and Approximate Occlusion feature.
I attach the preview thumbnail in nautilus; the "broken" file (file number 0147.png); and the correct png file (file number 0148.png)
Added subscriber: @JohanTriHandoyo
Added subscriber: @mont29
I really do not see what we can do with those info… To investigate a bug we need to be able to reproduce it!
And quite obviously, a .blend file to help reproducing the issue would also help a lot…
this is the file :D https://dl.dropboxusercontent.com/u/13769882/png%20render%20error.zip?dl=1
Hi Bastien, to answer your question:
1). Sometimes it's corrupted sometimes it's not. I render it again on frame 147, but everything rendered correctly.
2). I assume that it happened randomly between other system. I use Ubuntu and also windows 7. But it appears when i use Ubuntu the randomly corrupt files occured.
3). Actually i just use Placeholders feature, so i just use one command for all the terminal and Blender will detect unrendered frame automatically.
The .blend file i attach is missing the background models, but it's okay i think.
Added subscriber: @Sergey
Uuuuhhh… So, you are disabling 'Overwrite' and enabling 'Placeholders', right? Not sure at all this is intended to work this way
Sergey, do you know whether 'overwrite'/'placeholder' handling could be considered “thread safe”? I kind of doubt that. Even worth across a network!
@JohanTriHandoyo suggest you try rendering by 'allocating' specific work to all of your processes, and see whether you still get corruption.
Added subscriber: @ideasman42
@mont29, i'm not really sure without having a dig into code (which i can do tomorrow). Meanwhile @ideasman42 might know more since this option was heavily used in the bi-farm.
Will have a look at that one then.
Ok… so, think this is a mere synchronization issue here. Blender does not take any insurance (like a global shared lockfile in render dir or so) that it synchronizes with other processes when handling render files. I think issue does not arise much on a local system (or high speed network one), but probably across a basic NAS (you did not specified used protocol, btw)…
Think what happens is, two different processes check for existence of file at same time, they both find it does not exists, touch it, render, and write result. I’d assume invalid PNG comes from writing at the same time at the end of the render (it’s not the safest thing to do, see also http://stackoverflow.com/questions/7842511/safe-to-have-multiple-processes-writing-to-the-same-file-at-the-same-time-cent).
Note I could not reproduce it here with a single machine, thus assuming issue arises much more easily with 'slow' NAS.
Anyway, not sure we consider that a bug, more like internal limitation? Fixing this would imply adding some filelock system imho…
So i change the LAN cables to a new one, it seems that my current cable is 5+years old :D interesting though, now the frames are all perfectly fine, no more corrupt frames even though i noticed that some of render terminal were rendering the same frame, i was hoping that it will become conflicted and that frame will be corrupted, but it's not.
By the way, i'm using multiple ubuntu terminal to render one shot because the Occlusion Preprocessing is only using 1 thread, and i read in the blenderartist forum that using multiple rendering will speed up the render time.
Thank you for all your help!
Archiving this for now… hard to investigate such issue, especially if we cannot reproduce anyway. I have a bit of a hard time believing a mere too old cable could cause that, but well…
