BGE leaves references in memory after quitting #44557
6 Participants
Reference: blender/blender#44557
Description:
When the BGE quits, there are still remainders of game engine objects in memory. This can be seen when inspecting
gc.get_objects()
. These are probably dead proxies, which apparently can still hold references.Tested on: Blender 2.74 and latest version from Git (
f8540d7fd5
)Running Kubuntu Linux 14.10 64-bit, compiled the version from Git with GCC 4.9.1-16ubuntu6
To reproduce:
Run the script again, and check the terminal for output. On my machine it shows:
I see two things amiss:
sys.modules
though, I checked that.Changed status to: 'Open'
Added subscribers: @dr.sybren, @brita
PS: for fun, press F8 to reload scripts, then run the script again. Boom, Blender crashes (if not, try again).
Added subscriber: @AngusHollands-4
We get into a heap of trouble (excuse the pun) because of persistent Python interpreter state, not only for internal objects, but also imported modules (any modules with mutable state that were imported before the engine was run will not be cleared after exit). This can be worked around, but it's a reflection of the issues observed.
Added subscriber: @Blendify
Added subscriber: @panzergame
it seems that the GameLogic module is never freed, if you defined the destructor function you will see that is never called.
This issue was referenced by
cd24871706
77ce7eb541
Changed status from 'Resolved' to: 'Open'
Commit
cd24871706
re-introduced problems with starting the game engine multiple times in the same run of Blender. I have reverted in commit77ce7eb541
.I've attached a project that shows this issue: #44557-memleak-reloading.tar.bz2. Run the BGE once, and it'll stop immediately (correctly, due to the
bge.logic.endGame()
call int44557.bge.submodule2.startup
). Run the BGE again, and you'll see a nice error message.It probably has something to do with the
t44557.bge
module already getting loaded from Blender, before the BGE starts. However, I feel that we should still support this (and apart from the memory leak, it works fine in current Blender).Added subscriber: @you.le
Hi, I can't reproduce this bug with recent Blender's version... Or I'm missing something? http://www.pasteall.org/pic/95569
@dr.sybren, as i understand the GameLogic module is never freed and reused the next frame because it contains only "globalDict" which is set as game end if we just reload an other file.
An other simple test is to do:
And then you will see that "a" is incremented for each run. But i debug the code in some hours and didn't find why it reuse the same module dictionnary because the module pointer and dictionnary is always a new modules, also the system modules dict is the same.
And even if we free the module by doing :
The issue is still here.
Trying to import "bge" or "bge.logic" or "GameLogic" outside bge raise an eror as exepted.
Also a big point that i forget : i renamed the folder bge to bge2
Apparently clear the sys.modules dictionnary before run the BGE and after run your script make it works. But it means that the BGE can't work on a python "context" modified by blender. So i propose to do like BGE : at blender start make a copy of the sys.modules and when laucnh the BGE load this copied dictionnary.
little fix patch : http://www.pasteall.org/67417/diff
Removed subscriber: @Blendify
We need to be sure that after exiting the game, the original sys.modules entries are returned (your patch would leave the python modules dictionary in the same state as a clean blender instance (not preserving running addons etc)
@AngusHollands-4: in the patch we first copy the actual sys.modules then set the clean one and at the game end we restore the copy of the actual sys.modules. So everything is ok.
This task is being closed because the BGE has been removed in Blender 2.8.
