Motion Tracking - (De)selecting Track Marker and Graph issues. #44640
Reference: blender/blender#44640
Windows 7
Broken: 2.74 (official)
Worked:
Adding to selection in Blender 3D window can be done with the Shift + LMB keys.
Deselecting a selected object by Shift + LMB click on it again works also.
Issue 1 - Movie Clip Editor
Adding track marker to selection by Shift + LMB works. But deselecting it with
Shift + LMB doesn't (2nd click on it = toggle selection). Box and circle deselect (i.e. c -> MMB) works.
In my opinion it should be possible to deselect (like circle deselect) a marker while clicking on it again.
Issue 2 - Movie Clip Editor Graph
RMB click on a tracking marker graph selects a tracking marker, but if another graph is selected,
it's added to the selection of tracking makers (Shift + LMB functionality). This makes a look up of
tracking markers difficult.
In my opinion it should be possible to RMB select only one corresponding marker, and Shift + RMB adding
to selection. But only one tracking marker graph can be selected at any time.
Issue 3 - Movie Clip Editor Graph
In the graph editor there is always a graph selected, even if in the movie clip
window all tracker markers are deselected (with A). Key A selects or deselects
all points. By the way why can I select the points? What is the purpose of this
function?
Added subscriber: @MichaelParucha
Added subscriber: @mont29
Sounds this one is for you too, Sergey?
First two issues are now fixed in git. Third issue is not an issue actually, selected curve in the graph view corresponds to an active track, which is almost always exists.
The purpose of selecting points to to reduce spikes by applying different operations.
Thanks for the report, and now seems all the fixable things are fixed :)
I have tested the issues in the recent Blender build. I had to use win64_cmake_vc2013.zip (build Fri May 15 09:25:54 2015) because the other Windows 64bit build was not available at this time.
The fix of Issue 1 is a little bit strange.
If I want to deselect a marker in the Movie Clip Editor (not Movie Clip Editor Graph), I have to Shift+RMB click exact somewhere (several try and error!) in the area of ca. 5-10 px (depending on zoom factor) around the dot in the center (yellow border area in screenshot). I tested his also with the circle select, and I get the same issue here, which is of course not so obvious, because of the radius of circle select area.
But if I want to select a marker or add to selection I only have to click somewhere near the marker...
Area of several try and error Shift+RMB clicks.
The three states of track marker
Oh well, first issue i thought was about de-selecting marker in the graph view which was not implemented and which it is now.
As for de-selecting in the clip editor you can disable center of a marker or pattern area or search area and depending on what the mouse is closer to that part will be de-selected. For initial selection all areas are being selected, so threshold feels a bit bigger.
It's not really ideal, but improving behavior a bit tricky, because desired behavior actually depends on particular use. And in any case, decisions about improvements are to be discussed outside of the bug tracker.
