Motion Tracking - Reopening file leads to jitter of tracked markes. #44675
Reference: blender/blender#44675
Windows 7
Broken: blender 2.74 (offical)
Reopening file leads to jitter of tracker markes.
I was working the chapter 2 tutorial from the Track, Match, Blend DVD in Blender 2.74.
After reopening and rendering the file the tracked markers "jittered" around despite the fact,
that they were tracked correctly the first time around. First I thought I was doing someting wrong.
Checked everything, tried diffrent tracking options, but still the same issues after reopening the
files.
So I finally tried a file from the dvd and rendert a sequence from frame 80 to 150 -> jitter.
Also attached are two frames the fist frame shows how far appart the tracked points are.
Added subscriber: @MichaelParucha
Added subscriber: @mont29
This is pretty much likely due to the fact that ffmpeg fails to seek in the stream reliably, which we can not really control.. There only two things to try:
Does any of those option help?
Added subscriber: @Sergey
@sergey. Tested with the hints you provided.
This would mean, that the movie clip has to be converted to an image sequence, or a different video format? But it is, what the proxy basically does, right?
Rule of thumb: First build a proxy, than track?
But what about older scenes that have to be retracked, because they don't work any more in new versions of Blender?
Don't know if this a bug, but when the Display Stabilization check box is set (Display panel), I can't mute the footage.
Proxy is only reducing memory used by the display, tracker uses original footage and proxies does not really affect on the seek code. but using timecodes (even keeping proxies disabled) is indeed recommended thing when working with movies.
If old files used to work and now they don't even with timecode enabled -- that totally worth checking. But for that it also needed to check files with the same version of blender which was used to store the files. So the question here: do you have tracked files which were done with proper timecode thing and which are now off?
Display Stabilization seems to be a bug, so please report it in a separate task.
If I understand this correctly, selecting time code index works independent of the generating proxies, right?
I deactivated the proxies in my test file and then the time code index and I got a jitter in the tracked marker, I wrote above it seems to work. Activated the time code again (first option of five) and the marker was stable again. Tested this with a second marker and it worked.
So I assume that the updated rule of thumb should be: First activate the time code index, then track. After changing the time code I have to reload the footage file (or save, close, open the file).
I will test this further, because the two added tracker markers have a high average error (above 2.0) and the corresponding empty in the 3d view jitters...
Older files. I have tested this with the file from blendfiles\02_camera_tracking\05_compositing\composite.blend (Track, Match, Blend DVD), and it doesn't matter if the time code is active in this case, because the tracked marker jitter. So as I assumed this works only if the time code was set before the tracking begun.
In order to make time code used you need to do:
And it indeed seems changing timecode does not really invalidates the cache, this will be fixed soon.
As for older files and timecode -- yes, this is correct that timecode is actually needed to be used during tracking. Otherwise it's not really guaranteed timing wouldn't go off :(
Knowing which Blender version was used to create a file is very useful. Unfortunatly I have never seen this information in blender, i.e. when opening, linking or appending a .blend file. But this would be certainly a feature request, and I would never mention such thing in the bug tracker... :-)
Not really intuitive, but it is possible -- run blender from the ocmmand line and pass --debug argument. Blender will be printing versions of the file to the console then.
I have checked this file blendfiles\02_camera_tracking\05_compositing\composite.blend with blender 2.62 (official), 64bit Windows.
I get jitter.
I have checked other files from the dvd with Blender 2.72 and 2.62 (both official, 64bit Windows):
NO jitter.
Thanks a lot @sergey.
Time to close then! :)
@mont29. I think that there were two open issues:
Quote: "And it indeed seems changing timecode does not really invalidates the cache, this will be fixed soon."
Quote: "Built Proxy (the button should actually tell "Build Proxy / Timecode")"
So please ask @Sergey if this can be closed for sure.
Yes, it's still on TODO list actually. Will try to address it prior to testbuild1.
EDIT: Those changes are now committed to Git.
