Blender Crash on Exiting #44701
Closed
opened 2015-05-13 21:41:50 +02:00 by Aaron Carlisle · 10 comments
Member
Windows 8.0
Intel HD4600
Broken: 2.74.5
Blender Crashes When closing with this error when running blender from CMD with Blender.exe -d
Memorryblock opendir: end corrupt
Close Blender and hope that it crashes so that it can be fixed :)
**System Information** Windows 8.0 Intel HD4600 **Blender Version** Broken: 2.74.5 Worked: (optional) **Short description of error** Blender Crashes When closing with this error when running blender from CMD with `Blender.exe -d` ``` Memorryblock opendir: end corrupt ``` **Exact steps for others to reproduce the error** Close Blender and hope that it crashes so that it can be fixed :)
Author
Member
Author
Member
Added subscriber: @Blendify
Added subscriber: @ideasman42
Would guess this is caused by DIR in winstuff_dir.c having a short path length (MAX_PATH=260) and sprintf(newd->path, "%s\\*", path); not checking the path length.
While using snprintf would likely fix this bug, then it will just fail to read the path, so its probably best to increase the size too.
Would guess this is caused by `DIR` in `winstuff_dir.c` having a short path length (MAX_PATH=260) and `sprintf(newd->path, "%s\\*", path);` not checking the path length. While using `snprintf` would likely fix this bug, then it will just fail to read the path, so its probably best to increase the size too.
Martijn Berger was assigned by Bastien Montagne 2015-05-15 15:00:47 +02:00
Added subscriber: @mont29
Martijn, mind having a look at this? Does not sounds hard, but you never know with windows… would be better to check this does not break something before committing. ;)
Author
Member
Any new this should be fixed before the release
This issue was referenced by b1a92f2b3a
This issue was referenced by b1a92f2b3acf529cf86202a2b799fed64d89c3dd
This issue was referenced by 0f28d24e2f
This issue was referenced by 0f28d24e2f9e15376aa9040ec061c26111b60118
Reference: blender/blender#44701
