select by level #44797
Blender Cloud
Documentation
Eevee & Viewport
Import and Export
Rendering & Cycles
Add-ons (BF-Blender)
Add-ons (Community)
Reference: blender/blender-addons#44797
This addon select all vertices which has the same level in X,Y and Z axis with the ability to set a positive and a negative threshold for the selection.Select by level.py
Added subscriber: @omar-1
Added subscriber: @Blendify
Added subscribers: @mont29, @ideasman42
Thanks for your submission. I’m a bit unsure about that feature, though, to me it sounds pretty specific, and quite similar to what we can already do with box-selection in 3DView? And if we really need/want this, would probably be better to do it in C core code.
Campbell, what do you think?
My main reason for creating this addon is:
I was working on a project and I had some very long texts and logos,so when I wanted to select the lower part of it I used the box selection tool but it was annoying to have to zoom in,select a part then pan to another part and select it.(because it is very long to select the lower part from far away).so I made this addon to have it done in a sec. + threshold control even if you select the 3 axis together.
And for programming it in C : I dont know how to do it in C,I just know python.
We already have a tool which does something quite similar to this.
Mesh -> Select -> Side of Active
Which selects all vertices +/- vertices on a single axis.
Though checking it now and it would be nice if it added an error threshold.
I can see your add-on does a bit more then this... but think this is getting in the area of being quite a specific tool.
We could have some more general add-on to select points depending on them being inside another object's mesh. Then you could setup advanced selection meshes with existing tools.
closing.
