Import FBX not working #44806
Closed
opened 2015-05-22 14:15:12 +02:00 by Walid Abushady · 13 comments
Windows 64-bit Nvidia Geforce GTX56
Version 2.74
Broken: 2.74 000dfc0
FBX file with baked animation created from Maya 2015 does not import into Blender
File "C:\Program Files\Blender Foundation\Blender\2.74\scripts\addons\io_scene_fbx\__init__.py", line 203, in execute
  return import_fbx.load(self, context, **keywords)
File "C:\Program Files\Blender Foundation\Blender\2.74\scripts\addons\io_scene_fbx\import_fbx.py", line 2276, in load
  _(); del _
File "C:\Program Files\Blender Foundation\Blender\2.74\scripts\addons\io_scene_fbx\import_fbx.py", line 2275, in _
  fbx_item[1] = blen_read_geom(fbx_tmpl, fbx_obj, settings)
File "C:\Program Files\Blender Foundation\Blender\2.74\scripts\addons\io_scene_fbx\import_fbx.py", line 1146, in blen_read_geom
  blen_read_geom_layer_uv(fbx_obj, mesh)
File "C:\Program Files\Blender Foundation\Blender\2.74\scripts\addons\io_scene_fbx\import_fbx.py", line 971, in blen_read_geom_layer_uv
2, 2, layer_id,
File "C:\Program Files\Blender Foundation\Blender\2.74\scripts\addons\io_scene_fbx\import_fbx.py", line 896, in blen_read_geom_array_mapped_polyloop
  blen_data, blen_attr, fbx_layer_data, stride, item_size, descr, xform)
File "C:\Program Files\Blender Foundation\Blender\2.74\scripts\addons\io_scene_fbx\import_fbx.py", line 753, in blen_read_geom_array_setattr
  _process(blen_data, blen_attr, fbx_data, xform, item_size, blen_idx, fbx_idx)
File "C:\Program Files\Blender Foundation\Blender\2.74\scripts\addons\io_scene_fbx\import_fbx.py", line 748, in _process
  setattr(blen_data[blen_idx], blen_attr, fbx_data[fbx_idx:fbx_idx + item_size])
ValueError: bpy_struct: item.attr = val: sequences of dimension 0 should contain 2 items, not 0
Open Blender
Clear scene by hitting A to select all then X to delete everything
Import FBX
Error message
**System Information** Windows 64-bit Nvidia Geforce GTX56 Version 2.74 Broken: 2.74 000dfc0 Worked: (optional) FBX file with baked animation created from Maya 2015 does not import into Blender Traceback (most recent call last): ``` File "C:\Program Files\Blender Foundation\Blender\2.74\scripts\addons\io_scene_fbx\__init__.py", line 203, in execute return import_fbx.load(self, context, **keywords) File "C:\Program Files\Blender Foundation\Blender\2.74\scripts\addons\io_scene_fbx\import_fbx.py", line 2276, in load _(); del _ File "C:\Program Files\Blender Foundation\Blender\2.74\scripts\addons\io_scene_fbx\import_fbx.py", line 2275, in _ fbx_item[1] = blen_read_geom(fbx_tmpl, fbx_obj, settings) File "C:\Program Files\Blender Foundation\Blender\2.74\scripts\addons\io_scene_fbx\import_fbx.py", line 1146, in blen_read_geom blen_read_geom_layer_uv(fbx_obj, mesh) File "C:\Program Files\Blender Foundation\Blender\2.74\scripts\addons\io_scene_fbx\import_fbx.py", line 971, in blen_read_geom_layer_uv ``` 2, 2, layer_id, ``` File "C:\Program Files\Blender Foundation\Blender\2.74\scripts\addons\io_scene_fbx\import_fbx.py", line 896, in blen_read_geom_array_mapped_polyloop blen_data, blen_attr, fbx_layer_data, stride, item_size, descr, xform) File "C:\Program Files\Blender Foundation\Blender\2.74\scripts\addons\io_scene_fbx\import_fbx.py", line 753, in blen_read_geom_array_setattr _process(blen_data, blen_attr, fbx_data, xform, item_size, blen_idx, fbx_idx) File "C:\Program Files\Blender Foundation\Blender\2.74\scripts\addons\io_scene_fbx\import_fbx.py", line 748, in _process setattr(blen_data[blen_idx], blen_attr, fbx_data[fbx_idx:fbx_idx + item_size]) ``` ValueError: bpy_struct: item.attr = val: sequences of dimension 0 should contain 2 items, not 0 location: <unknown location>:-1 **Exact steps for others to reproduce the error** Open Blender Clear scene by hitting A to select all then X to delete everything Import FBX Error message
Author
Author
Added subscriber: @dinokaizer
Author
Here is the FBX file{F178738}
Here is the FBX file{[F178738](https://archive.blender.org/developer/F178738/Example.fbx)}
Added subscriber: @mont29
Error is not with animation, it’s with mesh (UV data to be precise).
But I definitively cannot investigate a 57MiB file (fyi, once textified it gives over half a Giga of JSon file!). Please try to reproduce the issue with a much simpler one (ideally, a cube, or at least something reasonably small).
Error is not with animation, it’s with mesh (UV data to be precise). But I definitively cannot investigate a 57MiB file (fyi, once textified it gives over half a Giga of JSon file!). Please try to reproduce the issue with a much simpler one (ideally, a cube, or at least something reasonably small).
Author
I'm sorry but I cannot reproduce the error with any other file, I even tried removing the UVs in Maya but it makes no difference and still won't import
This is for a very important project and I am running out of options :(
I'm sorry but I cannot reproduce the error with any other file, I even tried removing the UVs in Maya but it makes no difference and still won't import This is for a very important project and I am running out of options :(
Added subscriber: @LevonHudson
I have access to Maya, i will have a look at the file and see if i can reproduce the error.
Author
Thank you so much for helping :)
Bastien Montagne self-assigned this 2015-05-31 18:35:38 +02:00
Closing for now, easy to reopen if/when required info is provided.
Author
That's too bad, levon have you got anything? I can't reproduce the error with any other file
Added subscriber: @catontheroof
Reference: blender/blender-addons#44806
