Cycles vieport - Transparency does not work in Material view. #44826
Reference: blender/blender#44826
Win7 64bit
GTX 560 monitors
GTX 970 rendering
Broken: 2.74 Official 64bit
Transparency does not work in material view. The only way I found to make it work is to switch to Blender Game renderer and change the parameter Alpha Blend from Opaque to Alpha Blend and than switch back to Cycles renderer. The problem is that the object behind the transparent object are not visible unless the object is selected with RMB. See the attached blend:
Transparency.blend
Open the Blend file - you can see through the monkey and whole cube is visible.
Deselect all (A) - you can see through the monkey bet the cube behind the monkey is invisible.
Added subscriber: @Traverso
Added subscriber: @Blendify
Im pretty sure this is an known issue a will be fixed with the opengl update am I correct?
Added subscriber: @Sergey
Transparency is viewport is not really correct because it doesn't sort faces by the depth, which causes wrong shading. Solving this is possible, but it's quite tricky to do without slowing viewport down, also better to happen after viewport code upgrade (which is currently happening in the branch).
So thanks for the report, but it's known TODO.
