Point density and voxel data don't work as particle textures #44901
Reference: blender/blender#44901
OS: Windows 7
CPU: FX-8350
GPU: R9 280x
Broken: 2.74
When a point density or voxel data texture is used as a particle texture, the entire texture is effectively position 0 on the colour ramp, even when patterns are shown when the texture is used as a material texture.
Create something such as a point density texture for particle system A, and use it to control "Density" of particle system B.
Particle system B fails to generate particles around those from system A with the default colour ramp. If the colour ramp is flipped, then Particle system B will generate particles everywhere, as it reads only position 0 on the colour ramp.
Added subscriber: @accursedCursive
Oops, I might have been wrong in adding this to "project: Addons".
Only noticed that as I pressed the submit button.
Added subscriber: @Blendify
Please post a simple .blend demonstrating the issue
untitled.blend
In this file, the particles dropped from the plane are supposed to control the particle emission of the cube.
I've got the point density texture that should be doing this as a control for rendered volumetric density as well, so you can render to see the texture that the particles dropped from the plane create.
Added subscriber: @brecht
These textures only work in the renderer, their (quite slow) preprocessing code is only executed as part of render initialization. Probably this would be considered a missing feature more than a bug.
Added subscriber: @Sergey
Wouldn't consider this a bug, point density is simply not hooked up to the particles texture sampling. Doing this will likely make particles even slower and use quite huge amount of memory at sampling state.
I made sure the report is linked from http://wiki.blender.org/index.php/Dev:2.5/Source/Development/Todo/Tools#Particles and closing it as a TODO now. Thanks for the report anyway!
You might want to note that voxel data textures can't control particles either, though something to solve the issue for point density textures would probably also solve it for voxel data.
