Geforce TitanX SSS material on GPU renders slow #44903
Closed
opened 2015-05-31 11:39:51 +02:00 by Martin Lindelöf · 21 comments
Win8 x64
Geforce TitanX
Broken: 2.74 2015-05-29 (buildbot build) hash:1a0c961
SSS rendering on the TitanX is slow, for me it's slower than CPU.
I've got contacted on BA.org by a french user having a TitanX and a Titan Black. On his system the Titan Black is faster than the TitanX on SSS rendering.
I mentioned it because he is also eager to see if there's a solution, and if it could be of any assistance to mention that the Titan Black (Kepler) is faster rendering SSS
than the Titan X (Maxwell) card.
Correct me if I am wrong but it could be that they are using different cuda kernels. sm_50 and sm_52 are for maxwell cards, TitanBlack being kepler is it using sm_35?
anyway happy if someone could investigate if there is a solution.
Just try and render a scene with a SSS material present, on a system with TitanX.
I added a simple .blend scene and two screenshots.
untitled.blend
**System Information** Win8 x64 Geforce TitanX **Blender Version** Broken: 2.74 2015-05-29 (buildbot build) hash:1a0c961 Worked: (optional) **Short description of error** SSS rendering on the TitanX is slow, for me it's slower than CPU. I've got contacted on BA.org by a french user having a TitanX and a Titan Black. On his system the Titan Black is faster than the TitanX on SSS rendering. I mentioned it because he is also eager to see if there's a solution, and if it could be of any assistance to mention that the Titan Black (Kepler) is faster rendering SSS than the Titan X (Maxwell) card. Correct me if I am wrong but it could be that they are using different cuda kernels. sm_50 and sm_52 are for maxwell cards, TitanBlack being kepler is it using sm_35? anyway happy if someone could **investigate** if there is a solution. **Exact steps for others to reproduce the error** Just try and render a scene with a SSS material present, on a system with TitanX. I added a simple .blend scene and two screenshots. [untitled.blend](https://archive.blender.org/developer/F182352/untitled.blend) ![render-cpu.png](https://archive.blender.org/developer/F182348/render-cpu.png) ![render-gpu.png](https://archive.blender.org/developer/F182349/render-gpu.png)
Author
Member
Martijn Berger was assigned by Martin Lindelöf 2015-05-31 11:39:51 +02:00
Author
Member
Added subscriber: @MartinLindelof
Member
I don't know if the maxwell card has to be faster here then the kepler card.
But I really think there is a high probability we could improve performance on maxwell in general.
I don't know if the maxwell card has to be faster here then the kepler card. But I really think there is a high probability we could improve performance on maxwell in general.
Which CPU do you have?
Author
Member
Intel i7-3820 3.6Ghz, Quad core stuff.
Usually my CPU doesn't outperform my GPUs (have two cards)
here's another test render comparison with my standard shader, regarding CPU vs GPU performance on my machine.
CPU is 70s
GPU is 9s
So it's weird to see my CPU outperform GPU on SSS, when usually it's so much faster. Gonna check with the french blender user if he can submit/contribute GPU renders Titan Black vs Titan X.
Intel i7-3820 3.6Ghz, Quad core stuff. Usually my CPU doesn't outperform my GPUs (have two cards) here's another test render comparison with my standard shader, regarding CPU vs GPU performance on my machine. ![render-watermelon-cpu.png](https://archive.blender.org/developer/F182729/render-watermelon-cpu.png) CPU is 70s ![render-watermelon-gpu.png](https://archive.blender.org/developer/F182730/render-watermelon-gpu.png) GPU is 9s So it's weird to see my CPU outperform GPU on SSS, when usually it's so much faster. Gonna check with the french blender user if he can submit/contribute GPU renders Titan Black vs Titan X.
Member
SSS is really really not nice on GPU's but that is to be expected. This is more about why the maxwell card performs less well then one would expect.
For that problem I expect some of the kepler specific hacks might actually improve performance for the SSS case. But I need tot run tests to see what is really going on.
SSS is really really not nice on GPU's but that is to be expected. This is more about why the maxwell card performs less well then one would expect. For that problem I expect some of the kepler specific hacks might actually improve performance for the SSS case. But I need tot run tests to see what is really going on.
Author
Member
Maxwell has performed good for me, except SSS. I will try and get some test renders Titan black vs Titan X from the french user.
And if you need me to run tests, I will help out!
Maxwell has performed good for me, except SSS. I will try and get some test renders Titan black vs Titan X from the french user. And if you need me to run tests, I will help out!
Added subscriber: @P2design
Hi all,
Here are my specs :
AMD FMX 9370 - 8 cores - 4.41Ghz
32 GB DDR 3
ASUS GEFORCE TITAN BLACK - 6GB
ASUS GEFORCE TITAN X - 12 GB
Blender 2.74 official release
Nvidia Drivers : 352.86
Here are the result based on Martin Blend.File.
Titan X run 5 time slower than Titan Black.
TITAN X
TITAN BLACK
This performance gap append on EVERY SHADERS, as soon as Experimental mode is enabled.
And the performance loss is more important on TITAN X than BLACK. Test made with same file, glass shader with samples bumped to 500.
TITAN X
TITAN BLACK
I hope it will help and you can improve Titan X performances.
I'm really not a good technician about these technologies... I just can say that Titan X is supposed to be faster as it has more CUDA cores and is not -_-°
Hi all, Here are my specs : AMD FMX 9370 - 8 cores - 4.41Ghz 32 GB DDR 3 ASUS GEFORCE TITAN BLACK - 6GB ASUS GEFORCE TITAN X - 12 GB Blender 2.74 official release Nvidia Drivers : 352.86 Here are the result based on Martin Blend.File. Titan X run 5 time slower than Titan Black. TITAN X ![Titan-X.png](https://archive.blender.org/developer/F182965/Titan-X.png) TITAN BLACK ![Titan-black.png](https://archive.blender.org/developer/F182967/Titan-black.png) This performance gap append on EVERY SHADERS, as soon as Experimental mode is enabled. And the performance loss is more important on TITAN X than BLACK. Test made with same file, glass shader with samples bumped to 500. TITAN X ![Titan-X-glass.png](https://archive.blender.org/developer/F182969/Titan-X-glass.png) ![Titan-X-glass-experimental.png](https://archive.blender.org/developer/F182970/Titan-X-glass-experimental.png) TITAN BLACK ![Titan-black-glass-experimental.png](https://archive.blender.org/developer/F182973/Titan-black-glass-experimental.png) ![Titan-black-glass.png](https://archive.blender.org/developer/F182974/Titan-black-glass.png) I hope it will help and you can improve Titan X performances. I'm really not a good technician about these technologies... I just can say that Titan X is supposed to be faster as it has more CUDA cores and is not -_-°
BTW....
If you need any other further tests, do not hesitate I'll be glad to perform them.
BTW.... If you need any other further tests, do not hesitate I'll be glad to perform them.
Author
Member
Ah yeah, can confirm that, from 8.5s to 28.5s to render a test scene when going from supported to experimental.
Added subscriber: @mont29
The Experimental kernel was added because of the increased memory usage and performance drop with enabled SSS. We are aware of that and hope to improve that in the future (CUDA kernel split should fix these issues).
Closing as Archived, as this is a ToDo.
The Experimental kernel was added *because* of the increased memory usage and performance drop with enabled SSS. We are aware of that and hope to improve that in the future (CUDA kernel split should fix these issues). Closing as Archived, as this is a ToDo.
Hi Everyone,
Did you have any other information about this fix?
Do you have any idea when it could be fixed?
Thanks for your interest and B.REGARDS
Hi Everyone, Did you have any other information about this fix? Do you have any idea when it could be fixed? Thanks for your interest and B.REGARDS
Added subscriber: @albron
Hello everyone,
Discovering this thread as I just got a Titan X and discovering this problem with "experimental" render enable (using SSS).
I tried on 2.75 and 2.76 and the problem is the same...
My specs:
Processor I7 4770
MB: Asus Z87 WS
GC : Gigabyte GTX titan X
WIndows 8.1
Very frustrating as I'm rendering characters so using SSS all the time...
Arghh...
Hope you guys will be able to fix this soon....
Thanks a lot for your good work and dedication to this great software.
Alex
Hello everyone, Discovering this thread as I just got a Titan X and discovering this problem with "experimental" render enable (using SSS). I tried on 2.75 and 2.76 and the problem is the same... My specs: Processor I7 4770 MB: Asus Z87 WS GC : Gigabyte GTX titan X WIndows 8.1 Very frustrating as I'm rendering characters so using SSS all the time... Arghh... Hope you guys will be able to fix this soon.... Thanks a lot for your good work and dedication to this great software. Alex
Added subscriber: @MohamedSakr
I got 2 cards, GTX 970 and GTX 780, testing with experimental mode with a SSS material
GTX 780 = 8 seconds
GTX 970 = 30 seconds
the same scene without SSS "just diffuse"
GTX 780 = 4 seconds
GTX 970 = 6 seconds
something is wrong with Maxwell kernel settings "probably registers"
I got 2 cards, GTX 970 and GTX 780, testing with experimental mode with a SSS material GTX 780 = 8 seconds GTX 970 = 30 seconds the same scene without SSS "just diffuse" GTX 780 = 4 seconds GTX 970 = 6 seconds something is wrong with Maxwell kernel settings "probably registers"
Hello,
I wanted to have some news about this issue...
Can I help in any way?
Testing scenes or things like this?
Thanks for your work and your feedbacks.
Alex
Hello, I wanted to have some news about this issue... Can I help in any way? Testing scenes or things like this? Thanks for your work and your feedbacks. Alex
7 Participants
Reference: blender/blender#44903
