Render preview in Cycles freezes Blender 2.74 when using both GPU cores #44933
Reference: blender/blender#44933
Ubuntu 15.04 64-bit, PC - Gigabyte 990FXA-UD3 Rev. 4 motherboard, AMD FX-9590 CPU, 16GB DDR3 1866mhz RAM, 2x Nvidia Geforce GTX 660 graphics cards
2.74
When I try to use both Nvidia 660's I have in my PC (by selecting "Geforce GTX 660 (2)" in the Compute Device of User Preferences), the program freezes during render preview (Pressing Shift+z) almost immediately, with only the checkerboard background displayed. If I select the top "Geforce GTX 660", preview and render runs fine. If I select the bottom "Geforce GTX 660", it freezes. If I select the very top option "Geforce GTX 660(2x)", it freezes. Still image and final/video rendering works great -- uses both GPU's and cuts render time in half. It is only during render preview that this happens.
Added subscriber: @TravLR
Added subscribers: @mont29, @ThomasDinges, @MartijnBerger
Does final render with progressive refine works fine for you? Does setting tile size to 1024x1024 makes final render to stuck?
Sergey,
Confirmed, both final render with progressive refine checked works without issue, and setting the tile size to 1024x1024 works fine without issue. Final render doesn't seem to show any signs of problems. It's only when I use preview render in the viewport that I get the checkerboard background and Blender freezes. Mind you, this only happens when I select it to use both GPU's on my machine, or when I select the bottom GPU only. Selecting the top GPU works fine, but it cuts my rendering capability in half because I'm only using 1 of 2 GPU's in my system.
I also swapped the graphics cards around to see if perhaps one of them was defective. Even with them switched, I got the same result: choosing the bottom GPU froze Blender during render preview, but choosing the upper GPU worked fine. I know it's also not defective PCIe ports, because SLI works fine in games on the Windows side, and Blender renders using both GPU's without issue.
Added subscriber: @Blendify
Neither of the developers or artists around here can reproduce the issue. It's likely something to do with particular hardware configuration. It might be a good idea to check if someone from blenderartist had similar problem.
Also, now when you're mentioning SLI -- you need to disable it. It might easily cause issues with Cycles.
So thanks for the report, but archiving for until someone from the developers can reproduce the issue.
Understood. Appreciate the open communication. I'll test once 2.75 has officially been released to see if the problem still occurs then. :)
