WaveFront(.obj) addon: When it was imported as individual object with 'Split by object ' option, dummy material is added. vertex group is not recognized definitely.
#45012
Blender Cloud
Documentation
Eevee & Viewport
Import and Export
Rendering & Cycles
Add-ons (BF-Blender)
Add-ons (Community)
2 Participants
Reference: blender/blender-addons#45012
windows XP/SP3 32bits
Broken: version 2.74 (sub 5), branch b'master', commit date b'2015-06-08' b'21:48', hash b'e1b8ed8', b'Release'
Worked: unknown
When it was imported as individual object with 'Split by object 'option, dummy material is added.
Export OBJ files with 'Objects as OBJ objects' option using an attached file.
Import exported OBJ files with 'Split by object 'option.
Dummy material is added.
4ColorsPlus1.blend
The current exporter uses weight of vertex to decide vertex group including face.
(See findVertexGroupName of the exporter).
However, I do not understand the grounds that vertex weight is used for.
There cannot be the relationship between them.
You can confirm it in this attached file.
4Colors.blend
When the obj files which I exported in an attached file are imported, one vertex group is insufficient.
The current exporter does not output the face data of the edge form.
Therefore, I revised exporter so that all of vertex group including all vertexs which constituted face owned face.
In addition, the correction about the dummy material is included in revised exporter.
I attach the py file which revised this bug.
{F188516}export_obj.py
Added subscriber: @sindra1961
Added subscriber: @mont29
Thanks for report, but no bug here:
@Bastien Montagne (mont29):
I understood it.
I use this personally.
Thanks.
I understood that the present processing was based on specifications.
It cannot be understood whether the present specifications are right to me.
