Cycles standalone problem with CMake #45021
2 Participants
Reference: blender/blender#45021
I'm trying to work with the recent built "8th june" , there is a problem with cmakelists.
CMake asks for these libraries:
OIIO, OpenGL, GLEW, OpenEXR, Boost, and possibly CUDA if I included it, LLVM & OSL if I included OSL.
in the simple case "only WITH_CPU_SSE":
it generates the project "I'm using VS2013, x64" , when I compile, it signals missing pthread.h "it didn't ask for pthread in CMake GUI"
it also asks for GLEW_MX_LIBRARY which is not included with the libs.
when generating with OSL, LLVM makes a problem, it requires LLVM_LIBPATH
I tried this folder "lib\win64_vc12\llvm\lib" but it doesn't work
I don't consider this as a real bug, but I need help, may be I'm doing something wrong.
I tried using CMake 3.0.1, and CMake 3.2.3, but I think the problem is in the cmakelists.
Added subscriber: @MohamedSakr
Is your build environment correct?
e.g the lib and cycles source folder is in the right spot. Can you post your file hierarchy here?
ok, you nailed it Thomas from the first shot, I didn't notice that it uses relative paths internally.
so pthreads should work fine now, what about LLVM_LIBPATH & GLEW_MX_LIBRARY part?
nvm, everything works in 1 click now after fixing hierarchy layout, thanks Thomas, it was my fault that I changed the folder name.
you can remove this task, cmakelists are correct and fine.
