long scrolled areas do not revert when switching objects #45197
Closed
opened 2015-06-25 21:28:39 +02:00 by Mark · 13 comments
Mac OSX 10.9.5, NVIDIA card
Broken: 2.75 RC2 Hash: c85a58a
Worked: ??
I had an object with a long list of modifiers, and scrolled to the bottom of the list. I then selected an object with a much shorter list of modifiers. The scroll bar stayed at the bottom, as if the second object's modifier list was as long as the first, until I scrolled up all the way, at which point i could no longer scroll down again into the empty space.
This gave me the false impression that there were no modifiers on the second object.
1 - open bug_report.blend
2 - select Cube_long
3 - scroll to the bottom of Cube_long's modifier list
4 - select Cube_short
5 - look at modifier list.
5 - scroll up. You'll notice the length of the scroll bar changes as you scroll. You can no longer scroll down.
bug_report.blend
**System Information** Mac OSX 10.9.5, NVIDIA card **Blender Version** Broken: 2.75 RC2 Hash: c85a58a Worked: ?? **Short description of error** I had an object with a long list of modifiers, and scrolled to the bottom of the list. I then selected an object with a much shorter list of modifiers. The scroll bar stayed at the bottom, as if the second object's modifier list was as long as the first, until I scrolled up all the way, at which point i could no longer scroll down again into the empty space. This gave me the false impression that there were no modifiers on the second object. **Exact steps for others to reproduce the error** 1 - open bug_report.blend 2 - select Cube_long 3 - scroll to the bottom of Cube_long's modifier list 4 - select Cube_short 5 - look at modifier list. 5 - scroll up. You'll notice the length of the scroll bar changes as you scroll. You can no longer scroll down. [bug_report.blend](https://archive.blender.org/developer/F197404/bug_report.blend)
Author
Author
Added subscriber: @markbosz
Added subscriber: @mont29
Bastien Montagne self-assigned this 2015-06-26 12:36:05 +02:00
Thanks for the report, but this is not a bug, rather a feature (allows you to switch between objects and find again what you were working on when switching back)… Code is working as expected anyway.
Added subscriber: @PawelLyczkowski-1
I agree with @markbosz that this is bad UX.
That would be useful only if it remembered scroll position per object.
I agree with @markbosz that this is bad UX. >allows you to switch between objects and find again what you were working on when switching back That would be useful only if it remembered scroll position per object.
Member
Added subscribers: @mark-32, @JulianEisel
Member
@mark-32, @PawelLyczkowski-1, unfortunately, this "bad UX" is happening in other cases as well. Like when opening a panel or dragging items outside of view bounds. They're not hard to fix, but this is rather low in priority IMHO. I'll definitely check it at some point though.
Member
Added subscribers: @ideasman42, @BassamKurdali
Member
I can confirm this is happening on Linux too.
I'd say this is a bug (albiet a low priority one): the scrollbar is suppose to calculate the window size, but in this case skips the window size is wrong, presumably not getting notification that the contents changed.
If it is a hard bug to fix, it might be best postponed, but if it is easy, maybe @ideasman42 would like to add it to the 'easy tasks list for new developers' (sic) ?
I can confirm this is happening on Linux too. I'd say this is a bug (albiet a low priority one): the scrollbar is suppose to calculate the window size, but in this case skips the window size is wrong, presumably not getting notification that the contents changed. If it is a hard bug to fix, it might be best postponed, but if it is easy, maybe @ideasman42 would like to add it to the 'easy tasks list for new developers' (sic) ?
This issue was referenced by 7213553c84
This issue was referenced by 7213553c84a34256322ce7f113a601ee442736fd
Member
Changed status from 'Archived' to: 'Resolved'
6 Participants
Reference: blender/blender#45197
