Disabling 'Use Material Caching' causes Blender to crash when calling LibLoad #45267
Closed
opened 2015-07-02 02:03:29 +02:00 by mobious · 5 comments
Windows 7 64-bit
Intel HD Graphics 4000
Broken: 2.75 (c6b042b)
Worked: 2.74 (000dfc0)
start.blend -- Contains an empty that runs the following script:
import bge
path = bge.logic.expandPath('//load.blend')
print('loading:', path)
bge.logic.LibLoad(path, 'Scene')
load.blend - Contains the default cube
Calling LibLoad in 'Scene' mode on any file causes Blender to crash if the 'Use Material Caching' option is disabled. This is almost certainly caused by fix 377822729c for another LibLoad/LibFree crash with material caching.
Extract the attached files to the same location and open start.blend. Blender will immediately crash upon starting the game engine. Reopen the file and enable the 'Use Material Caching' option under Properties -> System. The crash should no longer occur and the cube should load properly.
Additional Notes
  • It does not seems to make any difference if the loaded cube has a material or not.
  • Attempting to load a file that contains no objects appears to always crash Blender regardless of the current material caching setting.
**System Information** Windows 7 64-bit Intel HD Graphics 4000 **Blender Version** Broken: 2.75 (c6b042b) Worked: 2.74 (000dfc0) **Files** [start.blend](https://archive.blender.org/developer/F199377/start.blend) -- Contains an empty that runs the following script: ``` import bge path = bge.logic.expandPath('//load.blend') print('loading:', path) bge.logic.LibLoad(path, 'Scene') ``` [load.blend](https://archive.blender.org/developer/F199378/load.blend) - Contains the default cube **Short description of error** Calling LibLoad in 'Scene' mode on any file causes Blender to crash if the 'Use Material Caching' option is disabled. This is almost certainly caused by fix 377822729c for another LibLoad/LibFree crash with material caching. **Exact steps for others to reproduce the error** Extract the attached files to the same location and open start.blend. Blender will immediately crash upon starting the game engine. Reopen the file and enable the 'Use Material Caching' option under Properties -> System. The crash should no longer occur and the cube should load properly. **Additional Notes** - It does not seems to make any difference if the loaded cube has a material or not. - Attempting to load a file that contains no objects appears to always crash Blender regardless of the current material caching setting.
Author
Author
Added subscriber: @mobious
This issue was referenced by e61ead7d4c
This issue was referenced by e61ead7d4c0a0067fb55f6abb68f637a8fd21d1f
This issue was referenced by 2d25656e05
This issue was referenced by 2d25656e051b74707b22e8af2202aafc0bb6e132
Reference: blender/blender#45267
