OpenCL not working for AMD FirePro W5000 #45336
2 Participants
Reference: blender/blender#45336
Win7 64bit
AMD FirePro W5000
Details from Catalyst Control:
Hardware ---------------------------------------------------
Graphics Card Manufacturer Powered by AMD
Graphics Chipset AMD FirePro W5000 (FireGL V) Graphics Adapter
Device ID 6809
Vendor 1002
Subsystem ID 0B06
Subsystem Vendor ID 1028
Graphics Bus Capability PCI Express 3.0
Maximum Bus Setting PCI Express 3.0
BIOS Version 015.025.000.007
BIOS Part Number 113-C4170400-100
BIOS Date 2012/10/09
Memory Size 2048 MB
Memory Type GDDR5
Core Clock in MHz 825 MHz
Memory Clock in MHz 800 MHz
Total Memory Bandwidth in GByte/s 102.4 GByte/s
Software ---------------------------------------------------
Driver Packaging Version 8.982.8-120814a-145478C-Dell
Provider Advanced Micro Devices, Inc.
2D Driver Version 8.01.01.1253
2D Driver File Path /REGISTRY/MACHINE/SYSTEM/ControlSet001/Control/CLASS/{4D36E968-E325-11CE-BFC1-08002BE10318}/0000
Direct3D Version 9.14.10.0924
OpenGL Version 6.14.10.11774
Catalyst Control Center Version 2012.0814.2145.37083
AMD Audio Driver Version 7.12.0.7708
2.75
c6b042b
Changing compute device from CPU to OpenCL Pitcairn does not appear to change the load on the CPU or GPU during render. AMD System Monitor shows only CPU used in both cases. Render also takes exactly the same amount of time. This happens for both Blender Render and Cycles.
Added subscriber: @nranthony
Sorry, did not set Device to GPU Compute in the Render section of the Scene. When I do enable a simple scene render crashes. blender-app.exe continues to increase in RAM, to around 1.6GB, and then everything just disappears.
Simple blend file attached:coffeeMug.blend
Added subscriber: @Sergey
Make sure you've got latest beta driver from AMD installed, otherwise there's no way OpenCL will ever compile.
But even then we're having issues with FirePro W8000, driver just goes to some sort of infinite recursion and dies. Nothing we can solve from Blender side unfortunately.
Latest drivers installed and same issue occurs.
Can you please point me in the right direction to help with debugging the code? Maybe the W8000 issues would be a good place to start.
Thanks
Neil
I've committed some fixes which made W8000 made working for a simplier scenes. More complex ones might not work, also baking wouldn't work. You can check latest builds from builder.blender.org.
Unfortunately, there's no much you or me can do here, it's just limitations of AMD driver. We are collecting hardware related issues there http://wiki.blender.org/index.php/Dev:2.6/Source/Render/Cycles/OpenCL#Hardware_Issues so AMD can use the list for troubleshooting their driver. Hopefully it'll work :)
