UV Transfer with mirrored objects #45340
Reference: blender/blender#45340
*moving comment from old closed task https:*developer.blender.org/T44522//
We did encounter some new issues.
I sent the files to Bastien, and asked me to update the ticket.
We tested the transfert both in Blender and Maya (where all cases worked fine). You can find the files in the attachment. We do believe that Maya does test the mirror to see if it finds a match.
Also the file transfert_UVs_001.blend return the following error "Error: Source and destination meshes do not have the same amount of face corners, 'Topology' mapping cannot be used in this case" while the stats (vertex, faces, edges,...) are exactly the same.
(Bastien already explained to me why it does this)
transfert_uvs.zip
cheers
F.
Added subscribers: @francois.register, @CedricPAILLE
Added subscribers: @mont29, @Sergey
@mont29, not sure, is it a bug or something to be improved?
OK. So, first, the issue with pins returning error with 'Topology' transfer is actually that you are using subsurf modifiers. While destination geometry is always evaluated without any modifier (quite obviously, since we are defining its basis data), source is evaluated in its 'final' form, once modifiers have been applied. Solution is simple in this case - just disable subsurf modifier of your source pin before using the transfer tool.
Regarding the mirroring thing, there is really no bug here. First of all, other packages, while they can be a source of inspiration some time, are by no mean a reference we want to copy. Maya may be automatically trying different mirror axes to get a better match between meshes, but our matching logic does not - this is user's responsibility to make its meshes 'visually' match before doing the transfer. In your first file, just set XScale of target to -1 before doing the transfer and you are done.
Adding automatic checks along some axes would be reasonably simple, but then users will want a complete auto-match able to determine full translation/rotation/scaling transform needed to get best match… Such an option is for sure possible, will put it on our TODO list, but this is a feature request.
