Edge select broken in shaded display modes with Mirror or Array modifier and "adjust edit cage to modifier result" enabled. #45477
Reference: blender/blender#45477
As the title says, edge select is broken/impredictable if display mode is set to any of the shaded modes (solid/textured/material) either in glsl or multitexture shading, if the "adjust edit cage to modifier result" is enabled in the modifier panel.
Basically only object/background edges can be reliably selected, trying to slect any of the edges that end up drawn over the object results in a rather random one being bicked up (usually on the opposite side of the object).
Behaviour is normal in wireframe mode or if the modifier option is not set.
Switching viewport shading between glsl/multitexture doesn't change behaviour.
Switching the VBO option on/off doesn't change behaviour, nor does changing the Selection mode.
Added subscriber: @emilian
Sorry, forgot to mention:
this with blender built from git at commit:
3e83a0d92d
On linux 4.1.2 with nvidia-drivers 352.21 on a GTX 760.
Added subscribers: @Psy-Fi, @ideasman42, @mont29
Please always attach a .blend file, it helps us reproducing the issue. broken_edge_selection_with_modifier_applied_in_editmode.blend
Can confirm the issue, @ideasman42, @Psy-Fi, this is likely due to recent refactors?
Thanks for confirming and sorry about not attaching a .blend. I thought since it could be easily reproduced with modifiers on the default cube that wasn't necessary.
This issue was referenced by
8f1c1ef3a9
a597a380bb
Thanks.
