Blender 2.75-32157d8-win64 solidify crash #45605
Closed
opened 2015-07-29 15:51:18 +02:00 by Rawzombie · 6 comments
Windows 8.1 Pro x64, GeForce GTX 460
Broken: (example: 2.75-32157d8-win64)
Worked: (2.75a)
Blender crashes in edit mode (face select) when in solidify modifier check "Adjust edit cage to modifier result" and trying to select face
Create plane, add solidify modifier, check "Adjust edit cage to modifier result", choose face select, try select face, crash
In attached file just try to select face and blender crash
http://pasteall.org/blend/37347
**System Information** Windows 8.1 Pro x64, GeForce GTX 460 **Blender Version** Broken: (example: 2.75-32157d8-win64) Worked: (2.75a) **Short description of error** Blender crashes in edit mode (face select) when in solidify modifier check "Adjust edit cage to modifier result" and trying to select face **Exact steps for others to reproduce the error** Create plane, add solidify modifier, check "Adjust edit cage to modifier result", choose face select, try select face, crash In attached file just try to select face and blender crash http://pasteall.org/blend/37347
Author
Author
Added subscriber: @Rawzombie
Added subscriber: @Psy-Fi
Confirmed, let's check what's happening here.
Antonis Ryakiotakis self-assigned this 2015-07-29 16:04:05 +02:00
This issue was referenced by becf20e29f
This issue was referenced by becf20e29f606cff01d2e6595572b86e734a01d4
Reference: blender/blender#45605
