Bump or displacement turns to black #45628
Reference: blender/blender#45628
Windows 8.1, NVIDIA GeForce GT 630M with 2GB Dedicated VRAM
Broken: 2.75a
c27589e
I have mixed a several number of noise texture with mix rgb node and connected to a bump map. If the number of the texture nodes reach a certain number (about 27 not allways the same but maybe depends on the refreshing of the memory, i dont know...) the material change to black (the bump map is also black if I check with the Node Wrangler addon's viewer node). The bug appears in the viewport with render shading mode and also if I render the image. It's also there if I conect to the displacement output. If I connect to the bump map node and the displacement output too the problem goes with less textures. It doesn't matter if I use CPU or GPU render but with the OSL it's completely okay. If I used Musgrave texture the bug was still there. But if I connect the textures to a shaders color input in any cases it works fine.
Actually I don't know if it's a bug or an official limitation but I havn't found anything about it on the internet.
In the attached .blend file just connect or disconnect a few texture node to see the bug.
bug.blend
Added subscriber: @monsieur
Added subscriber: @nudelZ
its not a bug its a limit (check the terminal - Cycles: out of SVM stack space, shader "Material" too big.)
svm can't handle large shaders - use less nodes or osl...
Added subscriber: @Sergey
As @nudelZ stated this already it's just limitation of SVM shading backend, not considered a bug.
Thanks for the report anyway!
Thanks for the quick help guys!
