COLLADA exports animations values for Location in world space instead of local space #45687
Closed
opened 2015-08-05 17:04:41 +02:00 by Eric · 18 comments
N/A
Broken: 2.75 c6b042b
Worked: NO
DAE/COLLADA exporter generates animation curve output values for Location in world space coordinates instead of local space coordinates.
It seem this bug affects only the Location (i.e. "location.X", "location.Y", "location.Z") components for non-bones objets, the Rotation values seem to be correctly exported in local space (i don't have tested Scale components).
This bug does not affects the "matrix" type animations (commonly used for bones's animations) which are correctly exported in local space.
This is NOT an importation-side problem (this is obvious but i prefer to point that) since even Blender don't correctly import the file he just exported and the problem is the same in any other DAE viewer or 3D software.
This bug is old, i mentioned it few years ago, but it seem nobody to took me seriously. I don't think it is hard to correct this bug, this is a little bug, but corrupts all (COLLADA) animation data exported by Blender.
anim-test.blend
anim-test.dae
  1. Create a scene with animated objects where some are parented to others
  2. Export as COLLADA
  3. Check the firsts output key values for Localtion.X, Y and Z in the DAE file, compare with the transformations data of the : There is obviously a problem.
    3-bis) Look the original animation in Blender, re-import the DAE file just created, and look again the animation.
**System Information** N/A **Blender Version** Broken: 2.75 c6b042b Worked: NO **Short description of error** DAE/COLLADA exporter generates animation curve output values for Location in world space coordinates instead of local space coordinates. It seem this bug affects only the Location (i.e. "location.X", "location.Y", "location.Z") components for non-bones objets, the Rotation values seem to be correctly exported in local space (i don't have tested Scale components). This bug does not affects the "matrix" type animations (commonly used for bones's animations) which are correctly exported in local space. This is NOT an importation-side problem (this is obvious but i prefer to point that) since even Blender don't correctly import the file he just exported and the problem is the same in any other DAE viewer or 3D software. This bug is old, i mentioned it few years ago, but it seem nobody to took me seriously. I don't think it is hard to correct this bug, this is a little bug, but corrupts all (COLLADA) animation data exported by Blender. [anim-test.blend](https://archive.blender.org/developer/F220305/anim-test.blend) [anim-test.dae](https://archive.blender.org/developer/F220306/anim-test.dae) ![test-anim-FBXreview.jpg](https://archive.blender.org/developer/F220307/test-anim-FBXreview.jpg) ![test-anim-Open3D.jpg](https://archive.blender.org/developer/F220309/test-anim-Open3D.jpg) **Exact steps for others to reproduce the error** 1) Create a scene with animated objects where some are parented to others 2) Export as COLLADA 3) Check the firsts output key values for Localtion.X, Y and Z in the DAE file, compare with the transformations data of the <node>: There is obviously a problem. 3-bis) Look the original animation in Blender, re-import the DAE file just created, and look again the animation.
Author
Author
Added subscriber: @Sedenion42
Member
Added subscriber: @Blendify
Added subscribers: @GaiaClary, @Sergey
Gaia Clary was assigned by Sergey Sharybin 2015-08-06 12:38:34 +02:00
@GaiaClary, are you still around to help us with collada?
Author
i looked to blender's source code and strangely i don't see where is the problem (from what i understand of blender source code) since the exporter just puts the BezTriple.vec content in the DAE file... so, i can see only two possible mistakes: blender keep animation curves in world space (which seem strange to me) or the wrong fcurve is selected for exportation... Unfortunatly the Blender's architecture is relatively opaque to me...
Member
@Sergey: sure i am available.
@Sedenion42: i remember something strange goes on when using transformation type TransRotLock while it works when using transformation type Matrix (in the collada export options). it might be related.
i can take a look at this next week (if nobody else is faster).
@Sergey: sure i am available. @Sedenion42: i remember something strange goes on when using transformation type TransRotLock while it works when using transformation type Matrix (in the collada export options). it might be related. i can take a look at this next week (if nobody else is faster).
Author
@GaiaClary Note that Matrix animation export works only for bones. I don't know if it's a feature or a bug, but whatever you select in the export options, the animations for non-bones objects are exported in TransRotLoc way.
Member
It looks like the matrix_parent_inverse information gets lost during export.
I made the following test:
  • exported the 3 objects to collada
  • imported the objects back into the same blend file
  • copied the matrix_parent_inverse values from the original objects to the reimported objects.
Now the animation works again as expected.
As far as i know Collada does not support the concept of "matrix_parent_inverse". So the exported objects all have their matrix_parent_inverse "applied" to preserve the correct object locations in world space. But the animation curves are exported without applying the matrix_parent_inverse
So i guess the fix is to apply the matrix_parent_inverse also to the animation curves during export (if that makes sense)...
It looks like the matrix_parent_inverse information gets lost during export. I made the following test: - exported the 3 objects to collada - imported the objects back into the same blend file - copied the matrix_parent_inverse values from the original objects to the reimported objects. Now the animation works again as expected. As far as i know Collada does not support the concept of "matrix_parent_inverse". So the exported objects all have their matrix_parent_inverse "applied" to preserve the correct object locations in world space. But the animation curves are exported without applying the matrix_parent_inverse So i guess the fix is to apply the matrix_parent_inverse also to the animation curves during export (if that makes sense)...
Author
That make sens to me yes... and the "inverse parent" matrix has, to me, nothing to do in the transformations informations... ( I was forced to adapt my importer to properly compute this strange matrice by multiplying it by the local matrix ).
In my knowledge The "matrix_parent_inverse" is an exclusivity of blender. As far as i know, objects usually just have two main matrices, the local one, and the world-matrix, which is the result of the successive multiplications of parent's world-matrix with the local one (which give the final world transformation).
"world_matrix = local_matrix * parent->world_matrix" si what i do, and i'm not sur, but i think everybody (except blender it seems) do like that...
That make sens to me yes... and the "inverse parent" matrix has, to me, nothing to do in the transformations informations... ( I was forced to adapt my importer to properly compute this strange matrice by multiplying it by the local matrix ). In my knowledge The "matrix_parent_inverse" is an exclusivity of blender. As far as i know, objects usually just have two main matrices, the local one, and the world-matrix, which is the result of the successive multiplications of parent's world-matrix with the local one (which give the final world transformation). "world_matrix = local_matrix * parent->world_matrix" si what i do, and i'm not sur, but i think everybody (except blender it seems) do like that...
Author
In fact, all matrices and transformations should be "local" to object in the exported file... the world transformations are computed later, in the engine (whatever the engine) who multiply naturally the local matrix with parent matrix (except for root objects).
Member
Closed as duplicate of #43298
Changed status from 'Duplicate' to: 'Open'
Member
Removed subscriber: @Blendify
Member
I have started a rework of the animation exporter. The fix in D3070 already solves the issue, but it needs some refinement and further testing.
I have started a rework of the animation exporter. The fix in [D3070](https://archive.blender.org/developer/D3070) already solves the issue, but it needs some refinement and further testing.
Member
The reworked animation exporter/importer is now in master
Member
And now it is also in Blender 2.8
Member
6 Participants
Reference: blender/blender#45687
