light.type appears to not do anything when set in engine #45957
5 Participants
Reference: blender/blender#45957
when setting a lamp.type value
the manual says, accepts SPOT , SUN and NORMAL
however actually it accepts 0, 1, or 2
and setting these values appears to do nothing.
2.75a
DynamicLightManagerBugReport.blend
in this file, each lamp hook has a property Type, that is a integer, 0 , 1 , or 2,
these should set the lamps type to spot, sun and point, but do nothing.
Added subscriber: @JacobMerrill-1
Added subscriber: @Sergey
Added subscribers: @brita, @dr.sybren, @hg1, @panzergame
Added subscriber: @Psy-Fi
@JacobMerrill-1: You can't modify an object attribut by creating a similar object property and less if it named "Type" instead of "type". But if you test with KX_LightObject.type the effect is the same because shader are compiled for only one type of lamp.
@Psy-Fi: In the viewport refractor we will still need to recompile the shader to allow modify a lamp type ?
Added subscriber: @you.le
Added subscriber: @Blendify
This task is being closed because the BGE has been removed in Blender 2.8.
