problems with flat shaded object and normals_split_custom_set_from_vertices #46024
2 Participants
Reference: blender/blender#46024
Hi, I tested your fix, works great for smooth objects, but it has problems if object is flat shaded.
flat_split_normals.blend
Open the file, run the script and it will change both cubes to smooth shaded (before the fix flat shaded faces stayed flat).
If you try swithcing between flat and smooth shading and the cube that was smooth shaded before running the script changes properly, but the other one behaves strange.
Added subscribers: @mont29, @aivanis
No bug here, this is totally expected - when you set custom normals from vertices, and give 'use auto' zero value, you'll get the vertex default normal - which leads to smooth shading. If you want sharpness with custom normals, you need loops (aka face corners) ones!
