Cell Fracture Crash #46073
Closed
opened 2015-09-11 00:09:06 +02:00 by Denzyl · 7 comments
windows professional 64bit
nvidia gtx770 4GP
32 gb ddr3 ram
Intel core i7-4930cpu @ 3.40ghz
Broken: 2.75a
Whenever I use Cell fructure, Blender Crashes everytime I try fracture with material under "mesh Data" set to 1 or more.
select a cube open up cell fracture, set material to 1 or more and press OK. Crash
**System Information** windows professional 64bit nvidia gtx770 4GP 32 gb ddr3 ram Intel core i7-4930cpu @ 3.40ghz **Blender Version** Broken: 2.75a Worked: (optional) **Short description of error** Whenever I use Cell fructure, Blender Crashes everytime I try fracture with material under "mesh Data" set to 1 or more. **Exact steps for others to reproduce the error** select a cube open up cell fracture, set material to 1 or more and press OK. Crash
Author
Alain Ducharme was assigned by Denzyl 2015-09-11 00:09:06 +02:00
Author
Added subscriber: @DenzylBasterfield
Member
Added subscriber: @BrendonMurphy
Member
@DenzylBasterfield
Hi, confirmed crash.
If there's no material linked to the object, a crash will occur with "mesh Data" set to 1 or more. set a material to the object before fracturing & it works ok.
maybe a check could be added here if no material.
@DenzylBasterfield Hi, confirmed crash. If there's no material linked to the object, a crash will occur with "mesh Data" set to 1 or more. set a material to the object before fracturing & it works ok. maybe a check could be added here if no material.
Alain Ducharme was unassigned by Brendon Murphy 2015-09-11 02:56:01 +02:00
Campbell Barton was assigned by Brendon Murphy 2015-09-11 02:56:01 +02:00
Member
Added subscriber: @phymec
This issue was referenced by blender/blender@e3ff9b2044
This issue was referenced by blender/blender@e3ff9b2044666ae04fc614a37e59e3dd01eeab4f
Reference: blender/blender-addons#46073
