As Visual Keying is turned on, child object would not transform in local parent space after keying any key frame when parent has any transform animation. (Blender 2.5 version works properly) #46095
2 Participants
Reference: blender/blender#46095
Windows 10, GTX660
Broken: (Blender 2.75 or 2.7x)
Worked: (Blender 2.5x)
When Visual Keying is ON, child object would not animate in local parent space. Whereas, Blender 2.5x works fine.
Visual Keying OFF (Correct Result)
Visual Keying ON (Wrong Result)
Bender Scene Files:
parent_anim_bug_Visual_Keying_OFF(Correct_result).blend
parent_anim_bug_Visual_Keying_ON(Wrong_result).blend
In Blender 2.75 or 2.7x, make sure Visual Keying is ON, then, remake a animation behaving exactly the same as the first Correct scene does. Playback the animation, then you'll see the problem.
Added subscriber: @Rays-Lv
Added subscriber: @mont29
Thanks for the report, but no bug at all here. Visual Keying is here to key the real, 'visible' position of an object, in its transform fcurves. That means that once you visual-keyed an object, you can (should) remove any constraint (and parent relationship) from it, and you'll get expected animation. If you want to keep parenting & co, do not use visual keying!
So bug is not in 2.7x, but in 2.5x. ;)
