Inadequacy of hair lenght in particle edit and bugs of rendering #46112
6 Participants
Reference: blender/blender#46112
My project stopped again because of some problems to edit and render hair. I am not new in hair particles and mostly made grass, stones distributions by using systems. But now I am working on 3d portrait and responsiveness of hair are important in order to make good result.
So problems are following:
Imagine that working with hair must be with taking account length which may be shorter, but it's very ineffective.
Try swith on/of chidren.
Switch on/of vertex groups.
Go in and out particle edit mode.
Example file: http://www.megafileupload.com/dwWl/hair_problem_lenght.blend
Suggestion for additions: option to apply vertex groups as particle edit.
Added subscriber: @JanisGrinvalds
And try to comb hair and see how result differs when You go out of particle edit mode.
Addition to ticket:
After applying scale of emitter, hair changes length proportionally. So if something was sized down and applied, then hairs become larger in global scale.
Maybe blender could check if mesh is emitter object and offers to user apply scale together with hair particle parameters.
Added subscriber: @Blendify
Added subscriber: @zeauro
Particles workflow is quite old, have a lot of limitations.
Since 2.5 refactor, weight groups cannot be used as a starting point.
It was thought as is :
User is setting particle length of parents in particle edit.
Then, user adjusts relative length of children with weight groups or textures.
There is an option to see children in particle edit.
Particles code is not flexible enough to be corrected without breaking other aspects of particles.
A refactor of particles is needed with a better workflow allowing back and forth between weight painting and particle edit.
But no dev is available to do it before 2.8.
Your report looks like suggestions for this kind of refactor. But it is not valid as a bugreport.
You should respect guidelines and prove that something that was working in a previous release is actually broken.
If it is really the case.
You should precise your OS, computer spec.
Upload .blend file directly in bugtracker by a drag and drop.
ubuntu 14.04 64 bits Nvidia Titan Black
I can confirm that since Gooseberry changes.
Hair children length can not be set to zero by a vertex group like it was the case in 2.73.
children_length.blend
Attached .blend file does not look the same if it opened in 2.73 or in 2.74, 2.75, current master.
Added subscribers: @LukasTonne, @Sergey
While there could be some changes caused by Gooseberry project, i don't really see reason why cycles will render hair differently from the viewport. That's something to be looked into.
@LukasTonne, do you have any ideas here?
Here, cycles does not render shorter than in viewport.
Without a blend file that shows it, I think that can be a simple impression due to hair tip that can not be draw in viewport as thin as in render.
@zeauro, i've been testing render with original file and could have see the problem. But now the file is indeed gone..
@JanisGrinvalds, please attach simple .blend file with the issue you're having here to the tracker so it's not getting lost again.
With the attached file i can see difference between viewport render and viewport opengl only after doing final (F12) rendering. it could be caused bu difference in view/render settings in the particle system..
I confirm that I see same wrong refresh of viewport render after an F12 render. Tweaking a little bit a particle setting forces refresh of viewport render.
Added subscriber: @throwcode
Hi I'm seeing the same bug as reported by Janis Grinvalds...
I'm using Window 10 pro, 64 bit, Intel i7, 12 GB Ram, Blender 2.76. This bug also occurred in Blender's prior release 2.75a. In both cases while using Cycles renderer.
Description:
The issue involves the Particle System, Vertex Groups panel, Length section. When editing a Hair system that uses the Vertex Group Length section to vary the length of the hair using Weight Painting, Blender fails to properly represent the length of the Hair particles in the Particle Editor.
The bug is very easy to reproduce.
In Blender you will note that in the 3D View the hair is appropriately sized. However when you switch the Object Interaction Mode from Object to Particle Edit the Hair is a uniform length, at the longest setting. This makes it difficult to comb and cut!
Thanks.
TC
@Sergey could this be related to what I reported in #46312
Added subscriber: @mont29
Current state of particles is real hard for further fixes, especially when there were intentional changes in other parts of particle system which could cause regression in other configuration. Would consider all such report a TODO for until new particle system is laid down. Thanks for the report anyway.
