Angle and Factor limits in SimpleDeform modifier do not always working. #46136
2 Participants
Reference: blender/blender#46136
Windows 7 x32
Broken: 2.75a
c27589e
, blender-2.76-testbuild2Worked: (optional)
Angle and Factor limits in SimpleDeform modifier do not working when I enter the value using the keyboard.
And limits of +/- 180 degrees is very small. For example you cannot create a circle or pipe from plane.
Please increase the limit to +/- 360 degrees. Or it may be better to remove any limits for this field.
in SimpleDeform modifier in twist and bend modes.
I use the mouse to change the "angle". +/- 180 degrees limits is working.
Then I changed angle to 181 degrees by using the keyboard, limits are not working.
I changed the value of the mouse. Now limits from -180 to 286.479.
Then I changed angle to 290 degrees by using the keyboard. Now limits from -180 to 572.958.
Then I changed angle to 580 degrees by using the keyboard. Now limits from -180 to 1145.916.
In Taper and Stretch modes some problem with "Factor" field.
Added subscriber: @gtitaev
This comment was removed by @gtitaev
Сommits
2679eaa712
, blender/blender-staging@6537771410Added subscriber: @JoshuaLeung
Added subscriber: @mont29
Thanks for the report, but no bug here. This is not specific to said settings, all numbuttons with soft range != hard range will behave that way - that is, adapt their soft range when current value is outside of the original [softmin, softmax] limits (the odd values for degrees are due to the fact the up-rounding is done on raw values, i.e. radians (572.958° = 10 rad, etc.)).
Then can you increase the limit from +/- 180 to +/- 360 degrees?
Because to make a circle you need to use the keyboard. This can not be done with the mouse. It is not always convenient.
Done as
276732ee62
