Bug with Simply option when rendering #46255
5 Participants
Reference: blender/blender#46255
Windows 7 x64, GTX 580 3Gb for display, GTX 780 6 Gb for render
Broken: (example: 2.69.7
4b206af
, see splash screen) : 2.76 x64 RC2 (and 2.75 x64)Worked: (optional)
I checked the Simplify option in the Scene panel and set the subdivsion level for viewport at 0. I let the Render subdivision at 6.
The tail has a subsurf level at 2 and as you can see in the picture, the sticker which is a subdivided plane (no subsurf modifier) with a modifier shrinkwrap (settings in the picture) is no rendered as expected when Simplify option is checked. If I uncheck the Simplify option, the render is ok.
http://www.pasteall.org/pic/93476
Added subscriber: @EmmanuelLORANT
Here is a simple blend file : http://www.pasteall.org/blend/38231
Just check or uncheck simplify and hit F12.
Added subscriber: @mont29
Please always upload files here directly… bug_simplify.blend
Can confirm that results with simplify do not match those without it, not quite sure why, but you are using an insanely small level of offset for your shrinkwrap too, maybe a mere float imprecision issue?
Added subscriber: @zeauro
Bug is not relative to simplify option. Same result happens with subdivision surface modifier viewport level set to 0.
Problem is that shrinkwrap only takes into account viewport level of subdivision surface modifier.
It seems that Subsurf levels feature of shrinkwrap modifier does not work.
Added subscribers: @LukasTonne, @Sergey, @ideasman42
Good spot @zeauro, indeed currently we do not have a real way to ensure we get real 'render' DM (tagged as TODO in
object_get_derived_final()
).@Sergey @ideasman42 @LukasTonne I think this is a TODO/known limitation more than a bug currently?
This is indeed a limitation of current dependency graph. I've tried to solve this during my last GSoC and had system basical working. But then it was disabled because of huge issues in the Blender Internal's duplication code which couldn't really cache single DeivedMesh for render.
While i can see how annoying it is, it's not really a bug. Just a known limitation. So thanks for the report, but sending to archive for until we'll re-work duplication code in BI.
The general problem is that any interaction of 2 or more objects is based on the viewport settings, not render. For example this also applies to collisions in physics sims.
The rationale seems to be that higher subdiv for rendering is supposed to be a visual refinement of the mesh only. That it has consequences for other objects is an unfortunate design limitation that has to be taken into account on the artist side. I'm not sure if solving this for immediate modifiers like shrinkwrap (as opposed to incremental simulations with collision) is feasible in an acceptable way.
In my opinion, it would be better to back as it was before (if I remember well) : no options for render or at least a warning so no confusion is possible.
Or perhaps, put the Simplify option in Properties -> Render -> Render panel so when you click Render, you see immediatly that Simplify is checked or not.
