Index needs clean up #46282
Eevee & Viewport
Rendering & Cycles
Needs Information from Developers
Reference: blender/blender-manual#46282
Short Description
blender.org/manual/render/blender_render/textures/index.html
needs to be cleaned up
Added subscriber: @Blendify
Added subscriber: @gandalf3
Could you define what needs to be done? (e.g. what pages should be moved where, or how the section should be re-done?)
well the procedural texture section there is no need for it too link to the sub-pages for each node. So basically the tree is two in depth for a lot of sections
And actually these textures AFAIK are the same for cycles so maybe all this information should be moved to a different location
They are not the same as cycles textures (BI and cycles have separate procedural textures), but I see what you mean about going too deep.
This issue was referenced by 693
Is there any way to removing the links to the options and technical details for the procedural textures?
@Blendify Not sure what you mean..?
Never-mind the web version was not updated yet. It is rebuilt now and looks a lot better. You may want to add to the writing style to keep indexes shorter.
There already is a note to that effect here (more or less): http://blender.org/manual/about/markup_style_guide.html#table-of-contents
Cool thanks... Still trying to set up my build involvement
Thanks for the report :)
If you'd like any assistance getting the manual building, feel free to drop by the #blenderwiki IRC channel.
