Cycles fails to render when material contains UV mapped texture as volume input #46352
6 Participants
Reference: blender/blender#46352
Archlinux
Broken: 2.76 RC3
Cycles fails to get past sample 1 when a material uses a UV texture on a volume input (sometimes blender crashes or freezes, but this only happened twice).
I would expect it to ignore the nonsensical material and render otherwise normally.
Added subscriber: @gandalf3
Added subscriber: @mib2berlin
Hi, cant reproduce crash or freeze but texture is not included.
Opensuse 13.2/64
CPU Intel #4200
4 GB Ram
GPU Intel GN 965
Cheers, mib
Here's a .blend with the texture packed cycles_volume_UV_crash.blend
Hi, tested your new file with my workstation but no freeze or crash.
Preview render work until the 10 appointed samples .
Opensuse 13.2/64
Intel i5 3770K
GTX 760 4 GB
Driver 355.11
Odd, fails every time for me.
Rendering on GPU freezes the display and renders the system unusable (need to reset)
Archlinux x86_64
Intel Xeon CPU E5420
GeForce GTX 460 766 MiB
4.5.0 NVIDIA 355.11
Added subscriber: @Blendify
Nothing bad happening here no crash successful render
Added subscriber: @brecht
It's easy to make this crash in a debug build, an assert will be triggered.
The issue is that shader nodes requests certain attributes depending if there is a surface shader with
if(shader->has_surface)
. But they do not change the SVM code generation to disable looking up the attribute.That should either be fixed, or the SVM attribute lookup code should be changed to not crash when looking up an attribute that was not requested. That was done as an optimization but in hindsight is probably too fragile.
This issue was referenced by
91f1886b8e
Added subscriber: @Sergey
This is a bit of a tradeof between runtime check and memory usage by attributes which doesn't make sense. Since such a check was already done for geometry
find_attribute()
will add similar thing to SVM node.We can check if we want to have attributes always copied to the device instead later.
This issue was referenced by blender/cycles@77c4eddd8a
