Autosmooth/sculpt/viewport bug #46726
Reference: blender/blender#46726
windows 8.1 surface pro intel HD 4000 ;
windows 7 nvidia geforece Gtx 560
Broken: 2.76b
viewport does not update shading of model while sculpting on meshes with matcap set throught shadeless material with texture mapped to normal and Autosmoth checkbox checked in Normals section of object Data.
Create suzanne, add material in Blender Internal and check shadeless in shading section, go to texture tab. Add texture and choose any of this round ball images like here
https://www.google.pl/search?q=matcap+material&source=lnms&tbm=isch&sa=X&ved=0CAcQ_AUoAWoVChMIlrG2vZqByQIVCf5yCh1U2QDa&biw=2000&bih=969&dpr=0.8
go to mapping section and choose normal from coordinates section. Then go to object Data tab and check autosmooth checkbox.
Then add multiresolution subdivide few times, go to sculpt mode and start sculpting. Shading of model will update only if you exit sculpt mode and move back to sculpt mode.
blender_bug.blend
Added subscriber: @riceart
Added subscriber: @Psy-Fi
Autosmooth was never supported in sculpt mode as far as I know.
I'll be closing this as not supported. Regenerating autosmooth normals in sculpt mode would make sculpting quite slow anyway. It's just not possible to work like that.
Im not asking here to add autosmooth to sculpting. I think that turning autosmooth option off everytime someone enters sculpt mode might be solution for this. Leaving this unresolved will be confusing for some people.
Regards.
You have a point let me check if it;s possible
As said above, just adding
in sculpt_flush_update makes this work. You can even see custom normals now, but speed-wise it's unusable. The problem with mesh autosmooth is that it's a mesh variable and at the time we upload normal uploads GPU we only have access to the derivedmesh. It's probably possible to somehow hack this in though.
Sorry to bother, but trick with autosmooth checkbox works only if i use multiresolution modifier. I just discovered that if i apply midifier i get same visual bug no matter what position autosmooth check box is left. You can check this by downloading file that i atached in first post and just apply multiress modifier then try to sculpt.
Regards,
This issue was referenced by
4d33c37c9e
