Max Frames should either be MAX_INT or configurable without recompile #46859
Reference: blender/blender#46859
Irrelevant
2.76b
f337fea
A 2-hour video at 60fps greatly exceeds the current hard-coded limit of 300k frames.
In the past, this limit was 30k frames: http://lists.blender.org/pipermail/bf-committers/2006-April/014435.html
Obviously, this is a repeating problem. We should either set it to MAX_INT and be done with it, or change it to be configurable at runtime. Is there any reason not to set it to MAX_INT? The resources aren't actually used unless you extend your project to be that length, right?
I'm new to deving on blender but would be willing to help out however I can, filing this feature request to get discussions rolling about the correct solution.
Added subscriber: @cmyers
Added subscriber: @ideasman42
To use much larger int's, we would need to make sure the frame was never cast to a float,
At 300,000 we get 1/32 of a second precision for sub-frames (needed for motion blur), without any large changes we could increase the maximum frame to
524286
(which still gives 1/32, sub-frame precision).MAX_INT sub-frames wont work at all with floats.
With doubles MAX_INT has more than enough precision.
To check on precision at different ranges, see P293
So we can either bump the max frame a small amount, or go over the code checking we only ever use doubles for frame values.
Added subscriber: @Sergey
This isn't really a bug or a design task, this is something known and something we can't easily change because of the reasons explained by Campbell.
Sure we can go over the code changing float subframes to doubles, but it's just one of multiple things TODO. So thanks for the report, but archiving it as a TODO.
Added subscriber: @leance
In my opinion, switching to doubles simply delays the problem but doesn't solve it completely. Also there might be a performance impact even for smaller projects.
Perhaps in order to support movie clips of any length, segmentation should be considered. This way, doubles needen't be implemented and the code won't require a review. Currently, the problem is that the 300k limit also applies to rendering a video. So it's not possible to render video's longer than 83 minutes (@60fps). So even if you were to make multiple clips and put them back-to-front in the timeline you can't render the entire thing. It should be possible to segmentise, or compartmentalise if you will, the render process to just reuse the frame numbers in a next segment. This way only code has to be added to the renderer which is more interesting work and can be done quicker. That way a very real problem that is keeping Blender from being usuable as a movie editor tool can be solved, increasing Blender's target audience.
Correct me if I'm wrong please.
And yes, there will have to be some tricky code for proper subframing in the space between segments but I still think this is the most realistic solution.
Update: as of
44e10a5c66
- the maximum frame is now 1,048,574 which gives 1/16th subframe resolution.@leance - using doubles for time wouldn't impact performance in a measurable way. If we move to doubles, we could get better subframe precision than we have now - with an 100,000 years of 60fps video.
