Boolean modifier sometimes produces a hole at the intersection point. #46869
Reference: blender/blender#46869
Gentoo Linux, GPU: AMD 290x (using the open source radeon driver)
Broken:
95bc8389a9
Worked: I haven't check with older versions than git master.
Sometimes when using the boolean modifier, it produces a hole in the mesh instead of filling in the intersection point with faces. I'm guessing this only triggers on certain advanced geometry configurations. I suspect this because I'm using the boolean modifier on a mesh I've got from a brain scan (I did some clean up with the decimate and subdiv mod).
It also seems like there are also certain "sweet spots" for where these holes tend to appear. I've attached a file with an example of one such spot.
Added subscriber: @ZedDB
Added subscriber: @Sergey
I don't really see any holes in the mesh actually.
Ah, I had multiple problems with the boolean operator it seems... The one I attached were because of doubles. Or at least it seems to be the case as I didn't manage to get it to bug out anymore.
However the reason that I noticed that something was wrong were because when I tried to render the moving intersection plane with freestyle as a video, the lines would vanish on certain frames. It was really noticable on the bigger part of the brain. But because the smaller one (the one I attached previously) had the hole problem, and it were much faster when stepping between keyframes, I thought that was the main cause of the problem.
But when I tried to remove doubles on the big brain, none were found and removed. I should have stated previously that I have tried with a box shape instead of a plane, but it didn't help. Thankfully I did manage to find the cause for why the lines didn't render sometimes on certain frames. It seems like the boolean operation fails sometimes. So the brain doesn't get sliced at all sometimes on certain frames.
I've attached a new file with one of those frames (frame 69). Step to frame 68/70 and then back to 69. For me the boolean operation seems to work sometimes and sometimes it doesn't. Note that this time it is intersecting with a box shape...
brain_bool_test.blend
I can attach a screenshot and try earlier versions, but I thought because the new error doesn't seem to be because of doubles, I'll just upload a blend file again to see if you can reproduce it...
Can see the issue with the attached model. Will look later in possible fixes.
Added subscriber: @ideasman42
I guess the solution to this problem will be the new bmesh boolean stuff? I mean there is no point in trying to fix the problem with carve if it's going the get phased out soon anyways, right?
I saw that the bmesh stuff got merged into the master branch recently. I'm guessing that it is still a WIP as it fails to produce any good results even with a simple cube on cube boolean modifier action.
However, it seems to be much faster than the carve based boolean modifer for me. Now I can playback the (corrupt) brain animation at 3fps! Where it takes serveral seconds to step one frame with the carve lib.
@ideasman42 Just in case Sergey didn't mention this bug to you, the brain mesh could be a good test case for the new boolean operator. Because if it manages to construct a mesh where the carve lib failed, it would be a nice improvement (besides the potential speed gain).
Edit: Gah, I can't edit the task to update the attached blend file with the most recent one. Be sure to use the one in the comments :/
Added subscriber: @mont29
Assigning to you @Sergey for now, but maybe we could close it as TODO since we aim at replacing carve with new bmesh code?
Think this was already on Campbell's radars, and he've got an own task now to gather all the complicated cases for the boolean operation.
Personally, would rather not spend time on trying to fix Carve now, but maybe help Campbell to investigate BMesh boolean remaining TODOs instead. Hence, would consider a BMesh Boolean TODO actually.
