Some instances are not rendered to scale one 0 #46937
Reference: blender/blender#46937
CPU: Intel Core i7-2600 3.40GHz
RAM: 16 GB
GFX: nVidia Geforce GTX 560 Ti
OS: Windows 7 Professional 64bits
Broken: 2.76b Hash:
f337fea
Worked: (all win64) 2.76-rc3, 2.75a, 2.74rc2, 2.73a, 2.72b, 2.71, 2.70a, 2.69
To scale the last instance created to 0, the other instances (the same group) not be rendered.
*Anomaly detected: to put 2 values of the scale 0.0001, and the other to 0, only a few faces of other instances they are rendered. (scale example: x = 0.0001, y = 0.0001, z = 0)
last_instance_scale_0.blend
Added subscriber: @Wilson-14
Added subscriber: @Sergey
I'm not sure how this is possible to work in 2.72-2.76 actually, in own tests it never works since 2.72. The regression in behavior is caused by the following commit
1526620
.it is just a Blender Internal render code which isn't compatible with such kind of instancing. This depends on the order of objects listed in the scene and happens when "origin" object is created from the group scaled to zero. In this case re-scaling ti to non-zero group size does not work.
Will try to improve the instancing code, but it's already quite fragile so it might be just considered a TODO.
Added subscriber: @ideasman42
Developer note:
Tried to make it so render object is created with unit matrix and being instanced by the instancing code. This turned up to be not so much striaghtforward because of how object data is stored (it's applying transform) and how other instances calculates offset matricies (relative to the original instance). Don't think running into such complexity is really something to happen as a bugfix, more like something what belongs to more major instancing code refactor in Blender Internal.
However, we might consider the following quick solution:
P298: Fix #46937
Basically, we skip instances if they're too small and can't be visible anyway. Could break some corner cases perhaps.
@ideasman42, do you have strong opinion here?
Thank you for answering so quickly.
I think that any solution would be useful.
Make elements appear and disappear through scale is a useful resource in work "motion graphics". To have "instances" speeds up the work.
(sorry for my bad English)
Added subscriber: @mano-wii
Unfortunately, the proposed patch wouldn't work well -- it wouldn't render halos in the same way as they are in current Blender (scaling object to zero will still render halo on it's center, i.e.).
Here's another idea which kind of implements idea of having object in the database created with unit matrix:
P309: Another patch for #46937
This is better approach, but is quite hackish in implementation and wouldn't work well for particles, also texture space might be wrong.
Al this requires some more major changes in the render database which are rather a TODO. Meanwhile you can animate renderability/viewport visibility of the object instead. So thanks for the report, but it's now part of TODO (http://wiki.blender.org/index.php/Dev:Source/Development/Todo/Render#Render_Engine)
