BAM support for Compressed blendfiles #46996
Reference: blender/blender#46996
The current design is the following according to @ideasman42
The packer can ensure all files are uncompressed before sending.
I found some problems with that approach:
Problem
If I save a compressed Blend file ¿How should BAM respond when I try to commit it? ¿Should BAM prevent such operation, or should uncompress the file directly, despite the user decision?
If we want to keep the file compressed for the user but rather uncompress it only for file transference the workflow is the following:
Using uncompressed blends on local BAM session but compressed on BAM Server
The problem with this approach is that you cant compress (nor uncompress) the Blend file from a BAM session.
Workflow of BAM overriding user compressed option:
Since I can access the SVN repo directly, if my SVN already have compressed BAM files, every time I checkout and commit them the compress setting will be lost.
As you see you can't go around the compression without overriding user decisions.
With this approach a user will be commiting a compressed file to SVN and if someone edited it using BAM the file (and all linked files) will be suddenly uncompressed. That is dangerous because after some time a big project (like Kiribati) will grow from 100Gb to 1Tb of size, and will not fit on the standard 1TB workstations discs.
Proposal
What I propose is to let the user decide what is the best for her/him. If there is a problem with BAM taking too much to commit the user will just stop using compression (if he/she can effort it).
BAM pack could print warnings every time it founds a compressed file, to give the user a clue about why it takes too much time.
This way the server don't know and don't care if the file is compressed or not, the Blend file is consistent for BAM and SVN users, and more importantly, the user can choose con use compression or not according her/his needs.
Added subscribers: @GabrielCaraballo, @ideasman42
I think it doesn't have to be so complicated.
Bam has
local cache
- this is a directory to store data so you dont need to re-download the same blend files every time you checkout files.I think the local cache should always be uncompressed, otherwise doing a local checkout will be very slow.
If the user saves a compressed Blend file, we can silently uncompress when storing in the local-cache (when they commit it). But when they check it out again, it wont be compressed.
On the other hand - we could support compressed (track which files are compressed, re-compress based on this info). I just don't see this as very valuable since it adds quite some overhead to performing edits on the blend file - which is needed for Bam's typical usage.
I realize it can be nice to let the user choose - but in practice users will have this set and forget about it, them BAM will run very slow and they won't want to use it.
Maybe we can make a deal, adding a setting on BAM Client called "ALLOW_COMPRESSED_BLENDS" with a default on False.
If ALLOW_COMPRESSED_BLENDS == False
BAM client will uncompress downloaded files, but will not compress it again.
If ALLOW_COMPRESSED_BLENDS == True
BAM client will uncompress downloaded files, and will compress it again.
Something like (from https://developer.blender.org/diffusion/BAM/browse/master/bam/blend/blendfile.py;28429f297bc7abc3a9e94f8a179ab9df3b25b9d4$166 ):
If SVN already have compressed files BAM will be able to handle them, but will not compress the again.
If the user adds a compressed file BAM will uncompress it on cache, and send it to the Server uncompressed, the user file will remain compressed (will slow down some local checks a little bit, we can Warn the user about that), but next time the file is downloaded from server will be uncompressed.
Added subscriber: @mont29
Added subscriber: @dr.sybren
Superseeded by BAT?
BAM has been superseded by Blender Asset Tracer (BAT). BAT supports many of the features of BAM, and is actively being developed. All open tasks regarding BAM are closed, and the project will be set to read-only. If you use BAM in your own project, please consider migrating to BAT.
