new Bmesh boolean is deleting some of edges data, (Creases and Bweigh) #47129
13 Participants
Reference: blender/blender#47129
linux 64
7e6d096
new Bmesh boolean is deleting some of edges data, (Creases and BWeight), even though it keeps others. Its especially problematic for Bevel Weight since it's often set before applying boolean.
Old(left) vs new(right) behavior
Added subscriber: @niewinny
#64497 was marked as duplicate of this issue
Added subscriber: @Sergey
Could you attach an example file? - I just tested this and it worked.
Note that this may not be considered a bug - if mesh that the boolean modifier is on doesn't have the custom-data to begin with (booleans also wont add vertex colors, UV's etc if the mesh doesn't already have them).
Hey Campbell,
It looks like I provided a little missliding info. It do not work only if applied from below other modifier(this is important, bevel modifier for me).
so here are the screencast showing it,so You can replicate it.
first the new one.
bug1.webm
(or link https://photos.google.com/album/AF1QipPnGwacsMNP7Vdor44b4b2DgHUJaMGhVcjgFZK6/photo/AF1QipNk-JS3NNqrSLRGV6t4Oq3RreuXosMWQHGuVhql)
and the old one
bug2.webm
(or link https://photos.google.com/album/AF1QipPnGwacsMNP7Vdor44b4b2DgHUJaMGhVcjgFZK6/photo/AF1QipPywQWz5C1l8elQYKCQhylAohViyj-6EEkQFHfK)
as You can see the bevel weight(but not only) is not preserved anymore. It would be nice to have it but keep it mind that I have no idea how new bmesh mod works, it is still superior to old one though even with no edge layers save))
I used new buildbot
cd6c6ee
aswell, same thing linux 64Added subscriber: @mont29
Added subscriber: @ideasman42
Added subscriber: @Lambdadelta
Bevel weight still not preserved after bmesh boolean. This is especially annoying after removing carve solver, which previously can be used instead
Added subscriber: @LazyDodo
please attach a sample file (.blend file, not a video) showing the issue
marking as incomplete until additional information is supplied.
Bmesh boolean bug.blend
If you apply boolean then bevel weight disappear. I tested it on blender-2.79-737a5ef-win64-vc14
can confirm the weights disappear
since that was not mentioned,
creases disappear as well
Added subscriber: @WitoldJaworski
since there is something happening here
that was fixed at some point
as long as all models (active one and the one we boolean with ) got edge data enabled
it will no longer clear edges
Added subscriber: @lichtwerk
Not sure if we can close this?
(confirmed to work with storing the data on all participating meshes...)
Added subscriber: @AnthonyEdlin
Although it works as long as you check store data on the boolean mesh target, it seems like the system should be able to handle combining smartly.
I look into it a little bit and notice boolean code uses BM_mesh_bm_from_me first on boolean target mesh and then second on it's own mesh. This is used to merge the two meshes into one bm before intersecting. But if you look in BM_mesh_bm_from_me you can see that the function BM_mesh_cd_flag_apply that adds the crease and weight layers is only called if it is the first mesh used. This means that those layers only exist if the first mesh (in this case the boolean target) has those layers. I added code to ensure those layers exist also if the second mesh has those layers. Here is patch: #47129.diff
It seemed to fix the issue for me in my limited testing. I am totally new to bmesh code though, so don't really know what I'm doing.
Added subscriber: @Jeroen-Bakker
Patch available but needs testing.
Added subscriber: @MichaelWeisheim
Added subscriber: @howardt
I believe this is fixed if one uses the Exact mode of new boolean.
9e09b5c418
this was fixed back in 2.81 for old solver as well (option in geometry data tab needs to be enabled)
It can be closed
As said previously, it always worked if you checked store data on the boolean target. It's been that way since, well I just tested 2.79 bmesh boolean and it's the same. So it always worked if you remember to check it on the boolean target even if you don't have any need to have it checked on the boolean target.
I just tried on a build from
f2d26409e8
with the new Exact method and it also seems to NOT preserve the data if you don't have it checked on BOTH the original mesh AND the boolean target.It seemed like it wouldn't be a bad idea for it to preserve the data in the applied mesh if EITHER the original mesh OR the boolean target had store data checked, which is what the diff I proposed tried to do.
Since I tested in 2.79 I also notice that the Carve solver does preserve the data even if the boolean target does NOT have store data checked. So it's not like it was always this way, just the bmesh boolean has always been this way.
like @AnthonyEdlin said, this is still not "fixed" in the way many users expect this [we just had #83932 reported], but yes, 'old' way of storing the data works.
Note that now that the new "Exact" mode doesn't go through bmesh it preserves the data. Updated patch to compile on recent version in case anyone still wants bmesh boolean to also work.boolean_customdata_save.diff
