Crashes with white balance filter #47156
6 Participants
Reference: blender/blender#47156
Windows 10
Intel HD 4600
Broken: 2.76.5
Worked: N/A
Blender Crashes when adding a white balance to an adjustment layer strip or meta strip.
Added subscriber: @Blendify
Hey Thomas, can you please check? Afaik you added it. :)
Will check, but can't promise that I can do much this week (first week after holidays for me ;) )
Just checked if I can redo it but can't... see
@Blendify Always supply a file to make sure that I can redo it..
@ThomasDinges Did it crash on your side?
Greetings, Thomas
Added subscriber: @ideasman42
Please attach a blend file which fails (including image files).
Committed likely fix:
60fa2644cb
, @Blendify could you confirm?@plasmasolutions, I noticed the division here can easily perform a divide-by-zero:
https://developer.blender.org/diffusion/B/browse/master/source/blender/blenkernel/intern/seqmodifier.c;b211e4193f2ea1a1cffef6b4b76ae5597922fec2$199-201
It's casting
nan
tochar
inpremul_float_to_straight_uchar
,Also, even for typical operation, this will cause channels to go above 1.0. For HDR renders this is useful to support,
but probably color correction shouldn't be pushing colors into HDR range?
Added subscriber: @mont29
Assuming this is fixed for now, we can always reopen if not…
Changed status from 'Resolved' to: 'Archived'
I am still getting a crash but having trouble finding the limiting factor. And the scene is too big to share. I will try to get a backtrace later this week to see if that can show something.
Added subscriber: @troy_s
Hi @ideasman42,
writing from Sweden atm. - was urgently sent to a client last week as a programmer drone and therefore just saw your message. HDRs should indeed be able to go above 1.0, completely agree about the division by zero tough, that should be avoided! Do we have an internal division method that catches those cases or should I just do it manually (by never going beneath 0.00001 for every channel for example)?
I'll talk to @troy_s about the color correction as soon as I'm back... unfortunately won't be until Sunday this week.
@Blendify As said, a file (as simple as possible) where I can reproduce issues helps here - if you find something, pack it into a file and upload it.
Greetings, Thomas
I haven't exactly looked at the code, but I'm pretty sure that it isn't a Bradford transform, which could be added later as a toggle.
"but probably color correction shouldn't be pushing colors into HDR range?"
This sort of operation has to be done blind. That is, it should assume that all images fed to it are scene referred, that is, ranging from zero to infinity with no concept of black or white. This aligns with Cycles internal model, and I don't see any adverse issue here?
@ideasman42 do you see an issue I can't? I trust your wizened eyes on these sorts of matters. From a strictly colour transform side, there's not really much here.
