Sculpt mode with Mask modifier enabled result an instant crash #47170
6 Participants
Reference: blender/blender#47170
Note, crash is resolved, but normal calculation logic looks like it may not be correct still. (though it doesn't result in visible errors, just extra calculations).
Win 7 64 bit
Broken: 2.76b official and build
c986e93
As the title says; If you add a Mask modifier to a mesh (with a vertex group assigned), then switch to Sculpt mode...Blender will always crash for me. If you disable the modifier, switch to Sculpt mode and then re-enable the modifier...it'll crash once you start sculpting.
mask.blend: Just switch to Sculpt mode .
Added subscriber: @quacker
Added subscriber: @ideasman42
Caused by
4d33c37c9e
Added subscriber: @mont29
Crash confirmed, will have a look later.
Added subscriber: @Psy-Fi
Looked into some different fixes.
At first I looked into passing mapping data to
BKE_pbvh_update
(pass polygonCD_ORIGINDEX
anddm->numPolyData
), then use this to array to only fill in the subset of faces used in the final CDDM (needs the reverse of the orig-index array). In this report the orig-index data isn't available (although it could be required and made available if it was important).On further investigation I couldn't see why this call is even necessary, commenting all calls to
cdDM_update_normals_from_pbvh
, works well on my tests, with this report and with the file from #46726.@Psy-Fi, any hints on what case this is needed for?
Assuming I missed some test case and this call is needed:
This is a possible fix: P313: only update normals on deform derived meshes since constructive modifiers wont have aligned arrays.
Further issues
When testing this report, I noticed you can sculpt onto invisible parts of the mesh (not a new bug, checked 2.71, 2.75 and 2.76 releases).
makesBKE_pbvh_update
is running every redraw, where its mostly finding 0 nodes, yet it still runspbvh_update_normals
and allocates vertex array... which is never used (simple to return whentotnode == 0
, but probably best this bug gets sorted out first).cdDM_update_normals_from_pbvh makes sure normals are updated even when we don't use optimal drawing from pbvh. It basically flushes the changes from PBVH to the derivedmesh itself. It's mostly useful on non-solid draw mode or when we can't do optimized drawing with PBVH (check can_pbvh_draw function)
Note - if you comment this out, you'll probably be able to sculpt normally but your normals will be wrong in non-optimal drawing. The change is very subtle, you might miss the error unless you expect it, it should be apparent there. Try GLSL mode it should appear there.
This issue was referenced by
3e0f117ef5
@Psy-Fi, to fix the crash, committed check that the derived mesh isn't using a constructive modifier (it doesn't make any sense to copy normals between the arrays in that case - its random luck if their aligned or not).
Regarding your last comments, I think I see what you mean in principle, but I still can't see any shading difference with GLSL+Sculpt (matcaps / flat / smooth / with/without autosmooth ...).
When you have a modifier applied, the modifier stack will calculate the derived-mesh normals.
In the file from this report, for example - its calling
CDDM_calc_normals_mapping_ex
,in fact with a deform modifier, with and without autosmooth, its calculating normals in sculpt mode, see call stack: P314.
(IIRC auto-smooth normals were meant to be disabled while sculpting).
Changed status from 'Resolved' to: 'Open'
Re-opening this report, since there are some unresolved issues with normal calculation, (even though the crash is fixed).
@Psy-Fi, would you be able to show a test-case (simple blend file) that requires
to run?Added subscriber: @Sergey
Remaining confusion should now be fixed in
7776f03
