Inconsistent frame rotations, from normals, with hair and particle instance modifier. #47355
2 Participants
Reference: blender/blender#47355
2.76b
The initial rotation of objects generated from the particle instance modifier is a bit strange.
When beginning with a UV sphere, I can delete topology, and the "duplicated"/"generated" objects all maintain consistent orientations.
However, when deleting topology and extruding one bottom edge loop down, the objects from the hairs in the new faces have varying and uncontrollable orientations. I'm having a tough time understanding from the code exactly how this rotation (the frame rotation I believe) is determined, and if there's any way to control it.
Attached blend contains two hairy-objects and two "leaves" (or petals) with particle instance modifiers ("Create along path" is selected).
Left: UV sphere with some vertices deleted. (Works fine with or without deletion).
Right: UV sphere with some vertices deleted and an edge loop extruded down (and scaled a bit). This demonstrates the change in instanced-object rotation.
The same particle system is used on both sets.particle-instance-hair-rotations.blend
Added subscriber: @jaggz
Added subscriber: @Sergey
The way how particle calculates rotation is weird indeed. But fixing this should be combined with all other major reconsideration of the whole system because it is just unmaintanable anymore. This is planned for 2.8x project. So thanks for the report, but for now it's a TODO.
