Numpy complex numbers division bug on Win 10 #47363
6 Participants
Reference: blender/blender#47363
Win 8.1 / 64 bits
AMD A10-6700 APU
video : HD8670 D
Hash = b'f337fea' 8 Fev 2016
and also
Hash = b'f77110e'
I asked someone else to test this on Linux
and it seems to work fine
so this seems to be a bug on Win 10
in given file there is a problem with this division of complexx numbers in Numpy
z1 = 7.49+0.71j
z2 = 127.01705922171767+0j
z3 = z2/z1
print ('z1 =',z1)
print ('z1 abs =',np.absolute(z1),' z1 ang =',np.angle(z1, deg=True),' Deg')
print ('z2 =',z2)
print ('z2 abs =',np.absolute(z2),' z2 ang =',np.angle(z2, deg=True),' Deg')
print ('z2/z1 = z3 =',z3)
the angle for Z3 gives -174 degrees
but it should be around -5 degrees !
tested other values and seems to work but not for this division operation.
see thread discussing this
http://blenderartists.org/forum/showthread.php?392066-numpy-complex-division-error
divide-test1.blend
thanks
happy bl
Added subscriber: @rickyblender
Added subscriber: @mont29
This seems to be an issue with numpy itself… Did you try that directly from python console itself (without using Blender at all)?
trying to do it in winpython
but I asked some one else to test it in Linux blender
and it works fine
but not on win 10
thanks
happy bl
just did a test in winpython
and it works fine
I get the right angle at around 5 degrees
so guess it has something to do with bl some how
thanks
happy bl
Added subscriber: @MartijnBerger
@MartijnBerger maybe we should use latest version of numpy for windows? We are using 1.9 afaik, according to numpy release notes they are using more and more C99 builtin complex support, this could explain the issue?
@rickyblender which is the exact version of numpy you used to test outside of Blender?
I have an old Python installed on my machine but not Numpy
so got Winpython
http://winpython.sourceforge.net/
winpython 64 bits 3.4.3.7 python 3.4.3 AMD
which has most of the package including Matplot
wish I could have same things in BL
so only way for me to test it was to use Iptyhon
and it works fine
Also Eppo did a test on Linux and it also work fine
Looks like it is only on Win 64 that it does not work well
for some specific cases of values for the complex angle.
Did anyone else find the same error on Win 64 ?
thanks
happy bl
well… winpython 3.4.3.7 reports numpy 1.9.3… (https://github.com/winpython/winpython/blob/master/changelogs/WinPython-3.4.3.7.md).
Will let @MartijnBerger handle it from there, could be some bug in our version of numpy but cannot check that here.
Added subscriber: @brecht
I don't think Numpy has anything to do with this, the code in the description only uses Python's builtin complex numbers.
I was talking about these
print ('numpy z3 abs =',np.absolute(z3),'z3 ang =',np.angle(z3, deg=True),' Deg')
print ('numpy angle =', rad2deg(angle(z3)) )
this is using np or numpy values if i'm not mistaking !
ang =',np.angle(z3, deg=True )
that is the one that does not work giving -171 Deg instead of
ang = -0.09451065035724213 Rad -5.41506138450656 deg
some other equations seems to work so not certain what error it can be
you can remove the cmath module at top not beeing use anyway
it will still give same error !
how is it not using np ?
thanks
happy bl
Added subscriber: @Symmetric-3
I can confirm the issue. While it works fine on my Linux Mint 17.2 64 bit, I have the exact same problem on Windows 7 64 bit (same computer)
I'm using blender 2.76b on both (numpy 1.9.1)
Added subscriber: @Blendify
Please try with the latest version of Blender we have updated these libs since then.
Added subscriber: @LazyDodo
can confirm it's fixed with the latest libs.
