FBX partial animation fix #47397
Blender Cloud
Documentation
Eevee & Viewport
Import and Export
Rendering & Cycles
Add-ons (BF-Blender)
Add-ons (Community)
Reference: blender/blender-addons#47397
This patch addresses several issues related to animations which do not key every channel in an armature. These issues only manifest when the "Key All Bones" option is off, which is required for partial animations.
When sampling animations, the armature is not reset when switching from one action to the next. If an action leaves some channels unkeyed, you'll see a pose from the previous action on those channels. This patch resets the armature between actions.
The exported bind pose is whatever pose the armature happens to be in at export time, rather than the T-pose specified in edit mode. Animations that only key certain channels often rely on the bind pose being accurate. This patch resets armatures to the bind pose before exporting.
For single-frame animations (poses), the exporter simplifies all keyframes out of existence, because there is never any change. This patch keeps the first keyframe if it is different from the bind pose.
fbx_partial_animation_fix.diff
Added subscriber: @et1337
Added subscriber: @Blendify
Quick typo fix to accommodate non-armature animations.
fbx_partial_animation_fix2.diff
My test case:
character.blend
Here's a version that also exports components all together, i.e., it exports X, Y, and Z position even if only X position is keyed. Certain pipelines can't handle individual components correctly (I'm using Assimp)
fbx_partial_animation_fix3.diff
Can you please create a diff? https://developer.blender.org/differential/diff/create/
Would be simpler to review the patch :)
Closing this task, the diff is enough to handle the review. :)
