Add a good default UV map to our 'monkey' primitive. #47488
10 Participants
Reference: blender/blender#47488
We now have the option when creating a new mesh primitive to add a default UV map - but the monkey head has none currently.
This map cannot be procedurally generated like the other, once agreed on it should be hard-coded into the code, in a similar way to how the monkey geometry already is.
This project has 2 parts:
3c6709a63c
)Changed status to: 'Open'
Added subscriber: @mont29
Added subscriber: @abhishek12123
Removed subscriber: @abhishek12123
Added subscriber: @amdbcg
Who wants to go first? how are these UVs supposed to be generated? Should I put together seams around the eyes , mouth, ears, and get feedback from that?
Added subscriber: @major_rascal
hi, i wanted to make my first contribution to blender , i know about uv mapping and coding (c++) ...could i be of any help :)
Added subscriber: @ideasman42
If anyone likes to work on this, just go ahead, no need to ask first.
Check
3c6709a63c
which adds UV's to other primitives (a useful reference to see related code).Added subscriber: @ChauHo
Youtube video from Mysticduder have nice mesh pattern below. I people like this pattern I will make it symmetric and get coordinate for all points. Please tell me your ideas about it. Thaks!
Added subscriber: @pdlla
Hi, first time here. I'm assuming no one is working on this anymore? I'm giving this a shot :). Will also look into fixing default unwrap for the UV sphere. Someone on IRC mentioned it "looks like a truck ran over it" and suggested I start there. I didn't see a tasks for this though.
Added subscriber: @VukGardasevic
There is a task were the UV sphere is mentioned. It's #47478
Here is high resolution map with symmetry for monkey head. Please tell me your ideas guys. If happy with this I will finish clean up and list coordinates for all points.
PNG file:
SVG file (Inkscape):
Do you happen to have an screen cap of the seams that generated that map? (assuming it was done using unwrap in Blender)
I get pattern from this video from Mystic Duder:
https://www.youtube.com/watch?v=vu2jZwRmz1o
Blend. file with seams:
conKỷ.blend
@ChauHo
Thanks! I'm using these UVs now.
I modified the unwrap operation to output its UVs for the purpose of hardcoding Suzanne's UV map. I pasted the code below for my own reference since it's not something that should be in the code base.
(oddly enough, since the UVs are already there, I output them before the actual unwrapping, which makes the fact that this is in the unwrap function pretty arbitrary)
This would be ready to go except the face or loop order of the monkey seems to change in the following conditions:
*many here meaning > 20 tris but <= 60 tris and I know this because when adding deleting an icosphere with no subdivisions everything is ok, but breaks when subdividing once or more.
The weird part is I'm using the same code to generate the icosphere UVs and they work fine under the same conditions. The only difference is there are 20x 3 vertex faces in the icosphere versus 500x 3-4 vertex quads in the monkey.
To clarify, I have the monkey and icosphere UVs hardcoded. I iterate through each face of mesh and each loop of face and set the UVs when the primitives are created. The UVs are hard coded to this iteration order.
Well, I'll investigate more tomorrow. In the meantime, does anyone have any ideas? I'm getting the hang of how edit mode and bmeshes work but still overall pretty unfamiliar.
I set the UVs right after each face is created rather then after all faces are created and assuming the iteration order does not change. Apparently it does change in some circumstances. This works fine now in all conditions I tested it under but the code isn't quite as nice :(.
This issue was referenced by
a070a5befa
