Blender crashes direct after hitting render button (window closes whithout any warning) Render with cycles is a matter of luck #47500
5 Participants
Reference: blender/blender#47500
Windows 7
nvidia GTX 970
Intel 4,00Ghz Quad core i7
see text file for further information
Broken: 2.75a, 2.76 (no further versions tested)
THE CRITICAL PART: HITTING THE RENDER BUTTON
it's crashes very randomly, the first hit on the render button is mostly successful but the next render crashes very often
(window closes and is disappeared, whithout any warning)
even after restarting the computer, switch to CPU mode, reduce the light bounces..... the problem is still existing!
Here is the error message (i was able to take the Screenshot in a few milliseconds :D )
Couldn't unmap memory
Error: EXCEPTION_ACCESS_VIOLATION
(I assume, that i have enough RAM, VRAM and SSD storage even with 6GB left an a 120GB SSD)
Blend file and system information
{F284031}Material_Test.blend
Added subscriber: @mrnick1994
Please test with Testbuild 2: http://download.blender.org/release/Blender2.77/
okay, i've tested the version 2.73 and 2.77.
same problem!
disabled all unneccesary addons and hit render a couple times in the standard scene.
everything was fine.
then i have loaded the test scene with materials and it crashes again at the first try.
i've found something interesting in the console:
the weird thing is, that i also had this problem on 2 other iMacs with other blend-files.
it crashes not so often, but the chance is there.
maybe its a problem with a specific basic shader node with a particular setting?
Added subscriber: @brecht
I've been trying to reproduce crashes with this file using a GTX 960 on Windows 10, but so far I found no problems.
Looking at the world nodes, there are about 150 node groups and 300 images used. Not sure how they got there, but I doubt that was intentional. It would be good if you could tests rendering with all those unnecessary node groups removed, to see if that's related.
If the node group is unused, then I don't think the image will actually be loaded. But still it would be useful to look at the memory usage in the Windows task manager while it's rendering, to see if it's running out of memory. The error message seems like an error that might happen when running out of memory.
Added subscriber: @lvxejay
Do you have any settings enabled in the Color Management tab? If you are using Film, RRT, Log, or Raw color management settings, or have color curves enabled, or you are using one of the built in camera filters, Blender will crash upon rendering your scene. (These settings can be found in Scene Properties, next to the World Properties button, underneath the Color Management tab)
hi,
unfortunately, i can test this on friday at the earliest.
thank you so far for helping me out!
it's great to talk directly with the developers, who make this great piece of software better ;)
i'll donate some money to the blender foundation ;)
Added subscriber: @NikoLeopold
Added subscriber: @jared-2
Hey,
i've tested now the possible solutions:
@brecht
I deleted the uneccesary world nodes and opened the task manager.
then i've started the render process, the window closes immediately as expected.
the ram shows normal behavior, the ram load goes down a little bit when the window closes.
so
nothing unusual.
@jared-2
I haven't changed the settings there.
additionally, i've test it with some settings (add a film look, change the color spaces)
nothing changed. :(
so
I open the console and found this.
maybe, there is something wrong with the python software?
PROBLEM SOLVED
I disabled all addons again and hit the render button.
now
the renderer doesn't crash!!!!
then I enabled all addons step by step to see, if something causes the problem.
all addons were enabled, and blender runs stable.
maybe it was a combination of uneccesary world nodes and too much addons? :D
ahhhh
okay :D
it's the pro lighting sky addon, which causes the problem.
i've enabled it and connected to the world output in the node editor and it stops working again. -.-
maybe it's not the right place here for 3rd party addons here, is it?
Please report this issue to the Addon author then. We need clear and reproducable cases here, and issues with third party addons cannot be fixed here.
