F6-menu drops mouseclicks #47532
Reference: blender/blender#47532
Windows 7 64bit
NVidia GeForce 9800GT
Broken: 2.76b
f337fea
Worked: 2.67b
Rapid clicking in the F6 menu (e.g. changing number of edge subdivisions from 1 to 3) result in dropped inputs.
Note: the operator panel located in the (T) toolbar works as intended. Also, ctrl MMW in F6 value fields works as intended.
Open new file > enter edit mode > select edge(s) > W (specials menu) > S (subdivide) > F6 (redo menu) > rapidly click value field arrows to increase subdivisions > only 1/2 or 1/3 clicks register, depending on click speed.
Added subscriber: @DerekWatts
Added subscribers: @JulianEisel, @ideasman42, @Sergey
Can see the problem, but not sure what's the reasoning behind this. Maybe some design limitation or so.
@ideasman42, @JulianEisel, mind having some investigation here?
Am already investigating, fix incoming.
Caused by
c24be7ec6e
.Don't really want to touch event/handling stuff before release, but would fix like this:
P327: Possible fix for #47532
Guess I should describe fix a bit more...
Before
c24be7ec6e
,wm_handlers_do
always called handlers a second time with event valueKM_PRESS
in case of a double click. After it, this was only the case for non-LEFTMOUSE
events.Since
ui_popup_handler
(almost) always returnedWM_UI_HANDLER_BREAK
, the second handler iteration withKM_PRESS
wouldn't run. My fix just makes sure we returnWM_UI_HANDLER_CONTINUE
for double click events instead (causing second iteration to run).Changed status from 'Open' to: 'Resolved'
Committed
37b7b3a935
