Point light not working properly inside a volume while rendering with GPU #47649
6 Participants
Reference: blender/blender#47649
Windows 10 64 bits, Nvidia GTX 670
Broken: Blender 2.77 RC 1
b594b25
Point light not working properly inside a volume while using GPU. It lightens the material, but not interacts with the volume. With CPU rendering, it works fine.
Place a point light inside a volume, with another mesh to lighten.
The light in the example comes from HDRI environment map and from point light.
error1.blend Blend file with the problem
CPU viewport, working fine
GPU viewport, not working properly
Added subscriber: @Pablo-Trensardina
#47656 was marked as duplicate of this issue
Added subscriber: @mib2berlin
Cant verify on Blender 2.77 RC1.
Hi you set all samples to 0 in Sampling setting.
No Bug.
Opensuse Tumbleweed x86_64
Intel i5 3570K
GTX 760 4 GB /Display card
GTX 670 2 GB
Driver 361.28
Intel opencl_runtime_15.1_x64_5.0.0.57
EDIT: Don´t saw sampler settings at first view.
Added subscriber: @Cenda
I can confirm bug. GF960 GTX, Win10 64b, Blender 2.77RC1
2.76b is fine
Hi Cenek, you cant set sampling to 0 in 2.76b, it automatically switch to 1.
If you switch volume samples to 1 in 2.77 RC1 it is working too.
Mib
Added subscribers: @ideasman42, @Sergey
This is a forbidden configuration, which should not have ever happened. I managed to "break" the setup using python code, this will be fixed by @ideasman42 soon.
I also found default value for volume samples was wrong, it was fixed in
3d3d491
.The reason it works in 2.76b is because buttons were allowed to clamp values on display, which was causing other issues.
Just set samples to 1, and wait Campbell to fix python bindings so scripts can't violate this again,
Added subscriber: @lsscpp
Range clamping is working correctly now -
e4e21480d6
Considering the issue solved now. Thanks for the report!
